Master Configuration
This section describes the master configuration details for the integration. The following Master Configurations can be found from the Admin menu [M or General] > Master Configuration.
ERP Integration Master Configuration
The ERP Integration Master Config Master Configuration is used by Project Management integration.
To create ERP Integration Master Configuration:
1. Navigate to Admin Menu > M > Master Configuration.
2. Click '+' against the ERP Integration Master Configuration value in the master configuration table.
3. In the Master Configuration Details section, select the ERP Integration Master Config (W1-ERPIntegrationMasterConfig) business object.
4. Configure the following values in the Project Integration section:
• Set Project Business Object to “Project”
• Set Task Outbound Sync Request BO to “ERP Task Outbound Synchronization Request”
5. Configure the Outbound Message Information as follows:
Outbound Message Type
Usage
ERPTASKSYNC
Update
ERPTASKSYNC
Cancel
ERPTASKSYNC
Add
