Configuring Connections in Oracle Integration Cloud
After the packages are imported and verified, the respective connections have to be configured.
This section describes the procedure to set up the following connections:
OU REST ERP PM for WACS ERPPM
This connection is used to invoke Oracle Project Management REST API to get the Project details.
To configure OU REST ERP PM for WACS ERPPM connection:
1. Login to Oracle Integration Cloud and navigate to the connection.
2. In the Connection Properties section:
a. Select “restUrl” as the Connection Type.
b. Enter the ERP Cloud Host URL.
3. In the Security section:
a. Select Basic Authentication Security Policy.
b. Enter the ERP Username and Password to connect to Oracle Project Management.
4. Click Test at the upper-right corner.
5. After the connection is tested successfully, click Save.
OU REST WACS for WACS ERPPM
This connection is used to invoke WACS REST APIs to call Create/Update project API and to receive the Oracle Utilities Work and Asset Cloud Service activity details.
To configure OU REST WACS for WACS ERPPM connection:
2. In the Connection Properties section, specify the Oracle Utilities Work and Asset Cloud Service REST web catalog in the catalogURL section.
The REST Catalog URL follows this format: https://{host}:{port}/{tenant}/{domain}/{appName}/rest/openapi/iws/catalog
3. In the Security Policy drop-down list, select Basic Authentication.
4. Provide Username and Password to connect to Oracle Utilities Work and Asset Cloud Service.
5. Click Test at the upper-right corner.
6. After the connection is tested successfully, click Save.
OU ERP PM Cloud for WACS ERPPM
This connection is used to receive the project status event details from Oracle Project Management.
To configure the OU ERP PM Cloud for WACS ERPPM connection:
2. In the Connection Properties section, enter the ERP Cloud Host URL.
Example: https://ERP_domain_name.ds-fa.oraclecloud.com
Note: The Oracle ERP Cloud host name can easily be derived from the Oracle ERP Cloud login URL.
a. Select Username Password Token Security Policy.
OU REST Trigger for WACS-ERPPM
This connection is used to invoke the common error handler Oracle Integration Cloud flow.
To configure the OU REST Trigger for WACS-ERPPM connection:
2. In the Security section, select OAuth2.0 Security Policy.
3. Click Test at the upper-right corner.
4. After the connection is tested successfully, click Save.
