Construction Work Activity Operations
The following operations are supported in the construction work activites:
Install/Undo Install Tracked Asset
Tracked assets are created in Oracle Utilities Work and Asset Cloud Service and are in the regular storeroom. The user has to request to install the same asset in Oracle Field Service. Click Install Asset to view the assets in the Issued Asset drop-down list.
The field worker can install the tracked asset on the location. The location type and asset type should be same, else assets will not be shown in the
![The field worker can install the tracked asset on the location. The field worker can install the tracked asset on the location.](../WACS-OFS-SETUP-GUIDE-23B/images/install-tracked-asset-1.png)
The real time asset verification call will go to Oracle Utilities Work and Asset Cloud Service. After the successful response, the asset will be moved to Install pool in Oracle Field Service.
![The asset is moved to Install pool in Oracle Field Service. The asset is moved to Install pool in Oracle Field Service.](../WACS-OFS-SETUP-GUIDE-23B/images/install-tracked-asset-4.png)
The field worker can undo an asset installation from the Install pool. The asset that is undone will be put into the existing pool in Oracle Field Service.
![Shows selecting the "Undo Install Asset" option. Shows selecting the "Undo Install Asset" option.](../WACS-OFS-SETUP-GUIDE-23B/images/install-tracked-asset-5.png)
Install/Undo Install Non Tracked Asset
Non tracked assets are created in the Oracle Utilities Work and Asset Cloud Service application store room and they are installed in Oracle Field Service. Select the asset from the Issued Asset drop-down list on the installation screen.
A field worker can install the non tracked asset on the location. The field worker has provision to provide the badge number, serial number, and asset number. The real time call will be sent to Oracle Utilities Work and Asset Cloud Service. After successful response, the asset will be put into the Install pool.
![The field worker can install the non tracked asset on the location. The field worker can install the non tracked asset on the location.](../WACS-OFS-SETUP-GUIDE-23B/images/install-nontracked-asset-1.png)
![Shows selecting the "Undo Install Asset" option. Shows selecting the "Undo Install Asset" option.](../WACS-OFS-SETUP-GUIDE-23B/images/install-nontracked-asset-5.png)
Remove Asset
The field worker can remove an asset from the location which is already installed. The removed asset will be moved into the Deinstall pool in Oracle Field Service.
![The field worker can remove an asset from the location. The field worker can remove an asset from the location.](../WACS-OFS-SETUP-GUIDE-23B/images/remove-asset-1.png)
Install No Asset
This construction task does not require any action from the field worker. It is displayed in the
Finished Tasks group.
![Shows the asset in the finished tasks group. Shows the asset in the finished tasks group.](../WACS-OFS-SETUP-GUIDE-23B/images/install-no-asset-1.png)
Remove No Asset
![Shows the asset removed in the finished tasks group. Shows the asset removed in the finished tasks group.](../WACS-OFS-SETUP-GUIDE-23B/images/remove-no-asset-1.png)
Update Quantity
Field worker can update any extra quantity of equipment that is required apart from the planned quantity.
![Shows the asset removed in the finished tasks group. Shows the asset removed in the finished tasks group.](../WACS-OFS-SETUP-GUIDE-23B/images/update-quantity-1.png)
