Plugins Rendering Data
This section explains how each of the following plugins renders the data:
Measurements
Valid measurement types received from Oracle Utilities Digital Asset Cloud Service are assigned to “dacs_valid_measurement_types” property and are obtained in runtime as XML string and displayed in plugin.
The individualMeasurementType-to-form.xsl and individualMeasurementTypeEdit-to-form.xsl are used to style the UI forms to add and update measurement information.
The measurement information is consolidated into “dacs_measurements_output” property and made available for validateCompletion plugin.
Measurement reason types (dacs_measurement_meter_reason, dacs_measurement_gauge_reason) are populated based on the measurement type selected.
Resource Usage
resourceUsage-to-form.xsl provides the summary of the Resource Usage Details page from where crew can add timesheets, equipment, and other resource usage. It also displays the resource usage details entered.
individualTimeUsage-to-form.xsl used to display add/update time sheet screens whereas crewTimeUsage-to-form.xsl is used to enter and update individual and crew timesheets.
individualEquipmentUsage-to-form.xsl and individualOtherUsage-to-form.xsl are used to enter equipment and other resource usages.
Upon completion of resource usage which calls Oracle Integration Cloud (OU OFS DACS Resource Usage Details integration flow) and update the details in Oracle Utilities Digital Asset Cloud Service.
Service History
The following XSL are applied to render the UI:
• serviceHistoryTypes-to-form.xsl to show Service History List and Entered Service Histories
• downtime-to-form.xsl for Downtime Service History form
• failure-to-form.xsl for Failure Service History form
• questionnaire-to-form.xsl for Questionnaire and Inspection Service History form
• sh-to-form.xsl for General Service History form
• entered-sht-count.xsl is used to count the entered service histories per each service history type
• shAttachment-to-form.xsl to enter attachments
For asset level service histories: The valid service histories are displayed based on the service histories hold by “dacs_asset_valid_service_history_types” property.
For activity level service histories: The valid service histories are displayed based on the service histories held by “dacs_valid_service_history_types” property.
The asset failure information is displayed based on the values in the “dacs_failure_info” property.
The asset downtime reason is displayed based on the values in the “dacs_downtime_reason” property.
The allowed MIME types for an attachment can be defined under Allowed MIME types of the “dacs_upload_attachment_1” property. Also, the file size limit can be defined under this property.
The following BO categories are supported. (Questionnaire and Inspection are handled similarly):
• Questionnaire
• Inspection
• Failure
• Downtime
• General
For activity level service histories, failure service history is not supported.
Refer to Adding Custom Business Objects for more information.
If the completion message for service histories is greater than 655360, the message is split into multiple dacs_service_history_output(i) for asset level and dacs_planned_service_history_output(i) for activity level service histories respectively, where “i” values ranges from 1 to 20 (size upto 640KB) properties and are made available for the validateCompletion plugin.
Note: For any service history type, number of attachments at asset level and activity level together combined must be less than or equal to 15. An error will be generated if the user tries to enter an attachment more than 15 times for that respective service history.
Asset Component Install Exchange Undo
• assetQuery-to-form.xsl to show Install, Attach, Replace, and Undo operation screens.
• Every operation will have “dacs_asset_effective_date_time” property on the screen defaulted to Current Date/Time which can be modified by the user.
• Clicking Search and Add or Search and Replace for Install, Attach, and Replace operations calls Oracle Integration Cloud (OU OFS DACS Asset Query integration flow). If the response succeeds, assets details are received and the operation is performed successfully. If the response fails, a valid error message is displayed on the screen.
Validate Completion
This plugin is used to validate and construct the final completion message obtained from individual plugins that is sent out by Oracle Field Service to Oracle Utilities Digital Asset Cloud Service. Click Complete.
The plugin validates to check if there are any pending service histories and all the required service histories are completed.
If the validations are not successful, click OK and fix the issue. If the validations are successful, the completion message is written to a temporary file and navigated to the End Activity screen. Click Submit to send the completion message to Oracle Utilities Digital Asset Cloud Service.
The plugin populates “participation” node in the completion message with either “W1AW” or “W1AS” based on if the “Asset worked” was selected (check box selected) or not.
Lock Unlock
The index.html page provides the summary of Lock/Unlock status from where user can Lock or Unlock Activity.
Only on locking an activity crew can start the operations such as asset install, replace, remove, adding timesheet, equipment, and other details. A crew member can lock the activity without starting it. Once activity is locked by any crew it can be unlocked by himself or from dispatch console.
• The Lock Unlock functionality can be enabled/disabled by setting the lock.functionality property in the DACSOFSC_ConfigProps lookup to “true” or “false” in Oracle Integration Cloud. While creating the work activity, if lock.functionality is set to “true”, then crew can start the activity and perform operations only after locking the activity.
• If it is set to “false”, the Lock button in the Oracle Field Service is disabled. So, a crew can perform all the operations without locking the activity.
• When the lock.functionality property is set to “true”, if the activity is assigned to a supervisor and locked by the supervisor, assisting resources cannot perform any operation on this activity.
• When the lock.functionality property is set to “true” and supervisor does not lock the activity, the assisting resource can still modify the resource usage plugin. Supervisors should lock the activity to restrict the assistants to perform any operation.
• When the lock.functionality is set to “false”, assisting resource will have access to supervisor's activity. The assisting resource can perform all the operations, such as asset install, replace, remove, adding timesheet, equipment and other details, adding service histories etc…
Materials
• materials-to-form.xsl displays a drop-down containing list of trucks assisting the crew to update the truck inventories of selected truck.
• moveMaterials-to-activity-form.xsl displays Use/Undo Use Item, Install/Undo Install Asset, and Attach/Undo Attach component pages from the truck inventories.
• Click Sync Truck Inventories for an initial sync of truck inventories that can be performed from the dispatch console.
Customer Devices
• customerDevices-to-form.xsl displays a drop-down containing a list of manufacturers and models, and also displays a text box to enter the device Serial Number.
• customerDevices-edit-to-form.xsl is used to display the device record that is added to edit.
