Customer Devices
Crew can perform the following operations on the Customer Devices plugin:
Add Device
To add a customer-owned controlled device:
1. Start an activity and lock it.
2. Click the Customer Devices plugin.
3. Select the Manufacturer and Model, and enter the Serial Number of the device.Shows how to add a customer-owned controlled device.
4. Click ‘+’, and then click Save.
Remove Device
To remove an existing device:
3. Select the existing device and click ‘-’.
4. Click Delete to delete the device, and then click Save.
Update Device
To update the details of an existing device:
3. Select an existing device and click Edit.Shows how to edit an existing device.
4. Modify the required details and click Update.
