Configuring Admin Data in Oracle Utilities Digital Asset Cloud Service
This section describes the admin data setup in Oracle Utilities Digital Asset Cloud Service related to the integration. The Admin menus can be configured to be grouped alphabetically or by functional groups. The descriptions that follow will include both groupings.
Master Configuration
This section describes the master configuration details for the integration. The following Master Configurations can be found from the Admin menu > [M or General] > Master Configuration.
Digital Asset Integration Master Configuration
Head End System
Create a new or update an existing head end system for each external energy aggregator interfaced to Oracle Utilities Live Energy Connect.
To create a head end system:
1. In the Admin menu navigate to [H or Digital Asset Management] > Head End System > Add.
2. Enter a unique head end system and its description.
3. Specify the external system created for Oracle Utilities Grid Edge Distributed Energy Resources Management System.
4. Add a processing method for processing role Device Status Check. On the processing method, set the following:
Default Business Object: X1-CtrlDvcStatusCheckComm (Controllable Device - Device Status Check)
Default Outbound Message Type: Controllable Device Status Check
Activity Type
Create a new or update an existing activity type for the Controllable Device Status Check activity.
To create an activity type:
1. In the Admin menu, navigate to [A or Communication].
2. Add or edit the Controllable Device Status Check activity and its description. Refer to the embedded help for more information.
Communication Type
Create a new or update an existing communication type for the following Communication Types:
Controllable Device: Device Status Check
Controllable Device: Device Status Check Response
To create a communication type:
1. In the Admin menu navigate to [C or Communication Type].
2. Enter a unique communication type and its description. Refer to the embedded help for more information.
Service Task Type
Create a new or update an existing service task type for the following Service Task Type Business Objects:
Digital Asset Enrollment Request Task Type
Digital Asset Unenrollment Request Task Type
To create a service task type:
1. In the Admin menu navigate to [S or General].
2. Enter a unique Service Task Type and its Description. Refer to the embedded help for more information.
Business Flag Type
Create a new or update an existing Business Flag Type for the KWH Avoided activity.
To create a Business Flag type:
1. In the Admin menu, navigate to [B or Integration].
2. Add/edit the following:
Standard Name for kWh Avoided
Related Transactional BO for kWh Avoided Business Flag
Status
Description
UOM
TOU
SQI
Interval Size
Sync Request Process
The Sync Request Process is used to synchronize customer enrollment and unenrollment data from Oracle Utilities Digital Asset Cloud Service to Oracle Utilities Analytics Insights. Maintenance Object - Audit algorithms are responsible for instantiating subscription based sync request records.
To configure a Maintenance Object:
1. In the Admin menu, navigate to [M or Database] > Maintenance Object > Search.
2. Navigate to the following Maintenance Objects and configure the following:
Usage Subscription (D1-US): Under the Maintenance Object - Options tab, add the “Sync Request BO” MO Option with an option value “X1-DRDigitalAssetCustSync (DataRaker Digital Asset Customer Sync Request)”. Plug in the F1-GCHG-CDCP (Generic Change Data Capture) MO audit algorithm. When a change is detected on a program subscription, this algorithm is responsible for instantiating the sync request.
Contact (D1-CONTACT): Plug in the X1-CNTCDCDA (Contact Change Data Capture (Digital Asset Subscription Based)) MO audit algorithm. When a change is detected on a contact associated to an eligible program subscription, this algorithm is responsible for instantiating the sync request.
Device (D1-DEVICE): Plug in the X1-DVCCDCDA (Device Change Data Capture (Digital Asset Subscription Based)) MO audit algorithm. When a change is detected on a controllable device associated to an eligible program subscription, this algorithm is responsible for instantiating the sync request.
Service Point (D1-SP): Plug in the X1-LOCCDCDA (Location Change Data Capture (Digital Asset Subscription Based)) MO audit algorithm.When a change is detected on a device location associated to an eligible program subscription, this algorithm is responsible for instantiating the sync request.
Scheduling Batch Jobs
This section lists the batch processes used for Enrollment Sync and KWH Avoided file creation.
For Enrollment Sync
Batch Code
Description
X1-DACIL
DataRaker Digital Asset Customer Sync Initial Load
X1-DACEX
Digital Asset Customer Extract for DataRaker
For Kwh Avoided
Batch Code
Description
X1-KWHAV
kWh Avoided Business Flag Upload
