Configuring Connections in Oracle Integration Cloud
After the packages are imported and verified, configure the respective connections.
This section describes the procedure to configure the following:
OU FTP DACS for OUAI DACS DRMS Connection
This connection is used to communicate with Oracle Utilities Digital Asset Cloud Service using the FTP adapter.
To configure this connection:
1. Login to Oracle Integration Cloud and navigate to the connection.
2. Set the FTP Server Host Address (xxxx.com).
3. Do not modify anything on the FTP Server port and SFTP connection tabs.
4. Select the FTP Server Access policy on the Security policy tab and enter the Oracle Utilities Digital Asset Cloud Service FTP Server username and password.
5. Configure the appropriate Agent Group if applicable.
6. On the Connection page, click Test.
7. After the connection is tested successfully, click Save.
Note: Make sure the FTP Server is setup and configured in Oracle Utilities Digital Asset Cloud Service.
OU REST DACS OS for OUAI DACS DRMS Connection
This connection is used to communicate with Oracle Infrastructure Cloud Object Storage using the REST adapter.
1. In the Connection Properties section, enter the object storage API endpoint in the Connection URL field.
The Connection URL follows this format: https:// objectstorage.{region}.oraclecloud.com
2. In the Security section:
a. Select the OCI Signature Version 1 security policy.
b. Provide the following Object Storage information:
• Tenancy OCID
• User OCID
• Upload the private key
• Fingerprint (obtained from object storage after register the public key for the appropriate user)
3. After the connection is tested successfully, click Save.
OU REST DACS for OUAI DACS DRMS Connection
This connection is used to communicate with Oracle Utilities Digital Asset Cloud Service using the Utilities adapter.
2. Add the Oracle Utilities Digital Asset Cloud Service catalog URL in the Catalog Url element.
3. Select Basic Auth on the Security tab and enter the Oracle Utilities Digital Asset Cloud Service username and password.
4. Configure the appropriate Agent Group if applicable.
5. On the Connection page, click Test.
6. After the connection is tested successfully, click Save.
OU REST DRMS for OUAI DACS DRMS Connection
This connection is used to communicate with Oracle Utilities Grid Edge Distributed Energy Resources Management System application service using the Utilities adapter.
2. Add the Oracle Utilities Grid Edge Distributed Energy Resources Management System catalog URL in the Catalog Url element.
3. Select Basic Auth on the Security tab and enter the Oracle Utilities Grid Edge Distributed Energy Resources Management System username and password.
OU REST OUAI OS for OUAI DACS DRMS Connection
• Tenancy OCID
• User OCID
OU REST for DACS-DRMS Connection
This connection is used to communicate with and from connected applications using a REST adapter. This connection is used as the request connection for internal integrations. A REST trigger cannot be used if it has an agent configured.
2. Select OAuth 2.0 or Basic Auth as the Security policy.
3. On the Connection page, click Test.
4. After the connection is tested successfully, click Save.
OU REST OIC for DACS DRMS Connection
This connection is used to invoke local integrations that can accept a multipart request for passing a multipart attachment reference.
2. Choose Rest API Base URL as the Connection Type.
3. Add the Oracle Integration Cloud connection URL in the Connection URL element.
Example: https://OIC_CloundInstance.com
4. Select OAuth client Credentials as Security Policy. For this security type, also add the Access Token URI, Client ID, Client Secret in the Security section. In the Optional Security section, add the Scope and select Send client credentials as Basic Auth Header for Client Authentication.
Alternatively, if you select Basic Auth on the Security tab, enter the Oracle Integration Cloud username and password.
