Type of Error | Action | Notification Type | Retry |
Remote Fault Example: WAM IWS or OFS API is not accessible | Process Stop | Email | Resubmit the flow from OIC. |
Business Fault Example: Invalid activity type | Continue | Email | Make sure the activity type exists in WACS and OFS, and then resend the request from WACS. |
Remote Fault Example: Child integration flow is not active | Process Stop | Email | Ensure "Activity Pull Update" integration flow is active and then resend the request from WACS. |
Remote fault Ex: OFS API invocation error | Process Stop | Email | Resend the request from WACS. |
Attachment file size exceeded | Process Stop | No notification is sent. Error message is replied to WACS. | Resend the request from WACS after fixing the attachment size issue. |
Attachment count exceeded | Process Stop | No notification is sent. Error message is replied to WACS. | Resend the request from WACS after addressing the attachments count issue. |
Remote Fault Example: WACS IWS invocation error | Process stop | Email | Once the service is up, resend the request from the respective OFS screen. |
Remote Fault Example: WACS IWS invocation error | Process stop | Email | Resubmit the error instance from OIC once WACS IWS is accessible. |
Business Fault Example: Missing data, such as: • Location/Organization is missing. • Invalid location for asset installation. • Asset does not exist. | Process Stop | Email | Perform asset query again with valid values, from OFS. |
Remote Fault Example: WACS IWS invocation error | Process Stop | Email | Perform asset query once WACS IWS is accessible or up. |
Remote Fault Example: WACS IWS or OFS REST API invocation error | Process stop | Email | Resubmit the error instance from OIC. |
Remote Fault Example: WACS IWS or OFS REST API invocation error | Process stop | Email | Resubmit the error instance from OIC. Or, run the scheduler flow manually. |
Business Fault Example: If the truck sent from OFS does not exist in WACS | Process stop | Email | Ensure both WACS and OFS data is in sync. Then, run the Schedule Storeroom Sync OIC flow. |
Remote Fault Example: WACS IWS invocation error | Process stop | Email | Once WACS service is accessible, run the Schedule Storeroom Sync OIC flow. |
Remote Fault Example: If child OIC flow is not accessible | Process stop | Email | Resubmit the error instance from OIC. Or, run the scheduler flow manually. |
Remote Fault Example: If store room sync child OIC flow is not accessible | Process stop | Email | User has to retry the activation from OFS. |
Remote Fault Example: WACS IWS invocation error or OFS API invocation error | Process stop | Email | If it is a WACS initiated update, resend the activity update request from WAM through the Process Activity flow. If it is an OFS initiated update request, perform Refresh Activity from OFS. |
