Error Handling
This section provides information about the different ways used to handle errors in the integration and also resubmitting the instances after rectifying the errors.
Summary of Integration Error Handling
Integration Process: OU ArcGIS OFS Admin Files Create
Type of Error
Action
Notification Type
Retry
External Mobile Control Data service unavailability
• Process Stop
• The OIC instance is marked as Failed
Technical Error Email
Reschedule execution in OIC
Failure in any of the file creation or any other errors
• Files already in Object Storage remain.
• Collect the error details.
• Process the next file.
• At the end, a summary notification email and, if applicable, a Technical Error Detail email are sent.
• The OIC instance is marked as Failed.
• Technical Error Email
• Business Notification Email with Summary of Files
Integration Process: OU ArcGIS OFS Work Tasks Process
Type of Error
Action
Notification Type
Retry
Invalid Token
• Process Stop
Remote Fault[Application down]
• Process Stop
Remote Error Email
Business Fault [Bad Request]
• The error is collected for each record.
• The EXTERNAL_REC_INFO field is not updated and still retains the value of N.
• OIC processing is successful.
Business Error Email with failed records
Fix the relevant issue and reschedule execution in OIC
Technical Fault[Xpath or DVM issue]
Business Error Email with errors as attachment
Fix the relevant issue and the next run should successfully process the record.
If the records cannot be fixed, update the EXTERNAL_REC_INFO field of the Task layer to Y.
