Oracle Integration Cloud
This section focuses on the monitoring Oracle Integration Cloud and troubleshooting any issues that occur during the integration activation.
Monitoring Integration Flows
Integration flows are monitored using the following:
• Project (for project based instances)
• Observability (for non project based instances)
To monitor the integration flows within a project:
1. Login to Oracle Integration Cloud.
2. Click Projects. On the navigation pane, click the relevant project.
3. Navigate to the Observe menu.
4. You can check:
a. Integrations to view the counts of various status of instances created per integration flows.
b. Instances to see instances of integrations of the project.
c. Future runs to see all the runs scheduled or started for scheduled integrations.
d. Audit to view and download design-time audit logs.
To monitor the integration flows outside the project through Oracle Integration Cloud Observability menu option:
2. Click Observability on the menu.
3. Select any of the following as required:
• Dashboards: To monitor the complete dashboard of integration.
• Integrations: To monitor each integration.
• Instances: To monitor instance and flow trace/activity stream of the integration.
• Error: To monitor the integrations in 'error' state. Re-submit the asynchronous integration flows.
Troubleshooting
To troubleshoot the errors in the workflow through the generated instances, you can set tracing level to DEBUG to generate detailed logs.
To enable DEBUG:
1. Select Configure Activation and then select the Tracing Level to be ‘DEBUG’.
2. Run the integration and check the activity stream which now will include the runtime log details of the flow.
3. If an activation fails, the Integrations page displays an error message.
Some of the sample cases are as follows:
• For any connectivity errors while activating the integration, make sure the trigger connection is successful. Test the connection and refresh the metadata, and then activate the integration.
• If the integration (Oracle Utilities Work and Asset Cloud Service initiated flows) is activated for the first time, ensure the Oracle Utilities Work and Asset Cloud Service catalog is configured accurately.
