Type of Error | Action | Notification Type | Retry |
Technical Fault Example: DACS is not accessible | • Send FAILURE ackType to DERMS • Process Stop | Error Email | Resend message from DERMS |
Business Fault (For each record processing where DACS enrollProgram returns - Status VAL-ERROR or ERROR) | • Set Error to the record’s responseCode and add to DERMS Responses Collection. • Process the next record. • At the end of the collection processing, send ERROR ackType and the response collection to DERMS. | None Enrollments created in DACS in Pending Status. DACS handles the business errors. | |
Business Fault (For each record processing DACS enrollProgram returns messageNumber = 10589) | • Error means the enrollment request already exists in DACS. • Ignore the error • Process the next record | None |
Type of error | Action | Notification Type | Retry |
Technical Fault Example: DERMS is not accessible | Process Stop | Error Email | Resend message from DACS |
Business Fault Example: Cannot create the subscription in DERMS due to null CIS_PERSON_ID. | Process Stop | Send Enrollment Sync Ack with Error | Fix the data in DACS. Resend message from DACS. |
Technical Fault (DACS HealthCheck API Error) | • Send FAILURE ackType to DERMS • Process Stop | Error Email | Resend message from DERMS |
Technical Fault (Read File Error) Example: File Empty | • Send FAILURE ackType to DERMS • Process Stop | Error Email Process Complete Email - Error | Resend message from DERMS |
Technical Fault (DACS Event Participation -Reserve Device API Error) | • Send FAILURE ackType to DERMS • Process Stop | Error Email Process Complete Email - Error | Resend message from DERMS |
Business Fault | N/A | None DACS handles the business errors |
Technical Fault (DACS Event Participation -Post Event Outcome API Error) | • Send FAILURE ackType to DERMS • Process Stop | Error Email Process Complete Email - Error | Resend message from DERMS |
Technical Fault Example: Source FTP or Source Object storage is not accessible | Process Stop | Error Email | Next scheduled run will pick up the files from DACS source content server or manually run the OIC process. |
Partial Processing Technical Fault During Processing in Loop Example: DERMS is not accessible | Process Stop | Error Email Process Complete Email (also includes list of files not transferred) | Rename the file in DACS content server by removing the “Error-‘ prefix in the filename then manually run the OIC Process. |
Business errors | N/A |
Technical Fault Example: DACS is down or inaccessible due to authentication error, network issue, technical etc. | Process Stop | Error Email Process returns FAILURE to DERMS | DERMS will retry the request |
Business errors from DACS (Should not happen) | Process Stop | Error Email Process returns ERROR for DACS '400' errors otherwise FAILURE to DERMS | DERMS will retry the request for FAILURE |
Business errors from DERMS or bad OIC configuration values | Request is not sent to DACS | Process returns ERROR to DERMS | Request will not be retried by DERMS |
