Configuring Connections in Oracle Integration Cloud
After the projects are imported and verified, the respective connections have to be configured.
This section describes the procedure to set up the following connections:
Configuring Oracle Utilities ERP Cloud for WACS-ERPPIM Connection
This connection is used to communicate with Oracle ERP Cloud Applications using the Oracle ERP Cloud adapter.
To configure the Oracle Utilities ERP Cloud for WACS-ERPPIM connection:
1. Specify the Service Catalog and Event Catalog URL or the ERP Cloud Host URL.
Enter the following:
• ERP Services Catalog WSDL URL: The ERP Services Catalog WSDL URL follows this format: https://{ERP Cloud host}/fndAppCoreServices/ServiceCatalogService?wsdl
• ERP Event Catalog URL: The ERP Event Catalog URL follows this format: https://{ERP Cloud host}/soa- infra
• ERP Cloud Host URL: Example: https://ERP_domain_name.fa.DC.oraclecloud.com
Note: The Oracle ERP Product Hub Cloud host name can easily be derived from the Oracle ERP Cloud login URL.
2. In the Security policy section, select Username Password Token.
3. Provide the Username and Password to connect to Oracle ERP Product Hub Cloud.
4. Click Test at the upper-right corner.
5. After the connection is tested successfully, click Save.
Configuring Oracle Utilities REST WACS for WACS-ERPPIM Connection
This connection is used to communicate with Oracle Utilities Work and Asset Cloud Service using the Oracle Utilities adapter.
To configure the Oracle Utilities REST WACS for WACS-ERPPIM connection:
1. Specify the Oracle Utilities Work and Asset Cloud Service REST web catalog to the catalogURL section.
The REST Catalog URL follows this format: https://{host}:{port}/{tenant}/{domain}/{appName}/rest/openapi/iws/catalog
2. In the Security policy section, select Basic Authentication.
3. Provide Username and Password to connect to Oracle Utilities Work and Asset Cloud Service.
4. From the Security Policy drop-down list, select Basic Authentication.
5. Click Test at the upper-right corner.
6. After the connection is tested successfully, click Save.
Configuring Oracle Utilities SOAP UCM Gen Svc for WACS-ERPPIM Connection
This connection is used to communicate with Oracle Universal Content Management using the SOAP adapter.
To configure the Oracle Utilities SOAP UCM Gen Svc for WACS-ERPPIM connection:
1. Specify the WSDL URL.
The Oracle UCM Web Service follows this format: https://{ERP Cloud host}/idcws/GenericSoapPort?WSDL
2. From the Security Policy drop-down list, select Basic Authentication.
3. Provide Username and Password to connect to UCM.
