Migrating from OFS Test to Production Environment
Migrate the following Oracle Field Service components from test to production environment:
Properties
To migrate properties from the Oracle Field Service test environment to production:
1. Export the properties that have names starting with “wam_” from test environment and import them into the production environment.
2. Export the common_utilities_product_code property from test environment and import it into the production environment.
Note: Make sure that the properties added manually in the test environment have been successfully imported in production environment.
Plugins
To migrate plugins from the Oracle Field Service test environment to production:
1. Export the AssetComponentInstallExchangeUndo plugin from test environment and import it into production environment. Configure the plugin secure parameters with production Oracle Integration Cloud details.
2. Export the LockUnlock plugin from test environment and import it into the production environment.
3. Export the Materials plugin from test environment and import it into the production environment. Configure the plugin secure parameters with Oracle Integration Cloud production environment details.
4. Export the Measurements plugin from test environment and import it into the production environment.
5. Export the PickUpWork plugin from test environment and import it into the production environment.
6. Export the PlannedServiceHistory plugin from test environment and import it into the production environment.
7. Export the ResourceUsage plugin from test environment and import it into the production environment.
8. Export the ServiceHistory plugin from test environment and import it into the production environment.
9. Export the ValidateCompletion plugin from test environment and import it into the production environment.
10. Export the AssetAttribute plugin from test environment and import it into the production environment. Configure the plugin secure parameters with Oracle Integration Cloud production environment details
User Types
To migrate user types from the Oracle Field Service test environment to production, export the customized user types from the test environment and import them into the production environment.
Glossary
To migrate glossaries from the Oracle Field Service test environment to production, export them from the test environment and import them into production environment.
