Configuring Connections in Oracle Integration Cloud
After the project is imported and verified, the respective connections have to be configured.
This section describes the procedure to set up the following connections:
OU BI ERP SCM for WACS-ERPSCM
This connection is used to invoke the BI Report SOAP service in Oracle Fusion ERP Cloud.
To configure the OU BI ERP SCM for WACS-ERPSCM connection:
1. Login to Oracle Integration Cloud and navigate to the connection.
2. In the Connection Properties section, enter the BI Report Service WSDL URL.
3. Click Test at the upper-right corner.
4. After the connection is tested successfully, click Save.
OU SOAP WACS for WACS-ERPSCM
This connection is used to connect to Oracle Utilities Work and Asset Cloud Service.
To configure the OU SOAP WACS for WACS-ERPSCM connection:
1. Login to Oracle Integration Cloud and navigate to the connection from the Projects page.
2. In the Connection Properties section, enter the catalog WSDL URL.
3. In the Security section:
a. Select Basic Authentication Security Policy.
b. Enter the ERP Username and Password to connect to Oracle Assets.
4. Click Test at the upper-right corner.
5. After the connection is tested successfully, click Save.
OU ERPSCM Cloud for WACS-ERPSCM
This connection is used to invoke Oracle Supply Chain Management cloud for ERPSCM using Oracle ERP Cloud adapter.
To configure the OU ERPSCM Cloud for WACS-ERPSCM connection:
2. In the Connection Properties section, enter the Oracle Fusion ERP Cloud Host URL.
Example: https://ERP_domain_name.ds-fa.oraclecloud.com
Note: The Oracle Fusion ERP Cloud host name can easily be derived from the Oracle Fusion ERP Cloud login URL.
a. Select Username Password Token Security Policy.
b. Enter the ERP Username and Password to connect to Oracle Supply Chain Management.
OU REST ERP for WACS-ERPSCM
This connection is used to invoke the ERPSCM REST APIs to get the Location/Organization/subinventories using REST adapter.
To configure the OU REST ERP for WACS-ERPSCM connection:
2. In the Connection Properties section:
a. Select “restUrl” as the Connection Type.
b. Enter the ERP Cloud Host URL.
b. Enter the Username and Password to connect to Oracle Utilities Work and Asset Cloud Service.
OU SOAP UCM Generic Service for WACS-ERPSCM
This connection is used to connect to UCM server in Oracle Fusion ERP Cloud.
To configure OU SOAP UCM Generic Service for WACS-ERPSCM connection:
1. Login to Oracle Integration Cloud and navigate to the connection from the Project page.
2. In the Connection Properties section, enter the WSDL URL.
b. Enter the ERP Username and Password to connect to Oracle Utilities Work and Asset Cloud Service.
OU REST WACS for WACS-ERPSCM
This connection is used to connect to Oracle Utilities Work and Asset Cloud Service using REST adapter.
To configure OU REST WACS for WACS-ERPSCM connection:
b. Enter the WACS Cloud Host URL.
OU REST Trigger for WACS-ERPSCM
This connection is used to receive and send stock item details across the Oracle Integration Cloud integration flows using REST adapter. It is also used to invoke the common error handler Oracle Integration Cloud flow.
To configure the OU REST Trigger for WACS-ERPSCM connection:
2. In the Security section, select OAuth2.0 Security Policy.
