Scheduling the Batch Process
Run the following Oracle Utilities Customer Cloud Service Batch Processes to create the extracts:
GL Extract For Oracle ERP Financial Cloud Batch Process
• Schedule the GLASSIGN and GLS batch processes to run at an appropriate time of day. These processes get sub ledger information in Oracle Utilities Customer Cloud Service and all information that has not been posted to the General Ledger, making them ready for extract.
• After both GLASSIGN and GLS processes have run successfully, schedule the C1-GLFCX batch process to create the GL extract file. Some of the batch parameters are already defaulted. Make sure these parameters are defined.
• fileName: Name of the GL extract file.
Note: The extract file name defined here should be defined in the property name gl.extract.filename.prefix of the CCSERPFIN_ConfigProps in Oracle Integration Cloud.
Example file name: GLEXTRACTFILE_{BC}_{BN}.csv. Only the GLEXTRACTFILE part is defined in gl.extract.filename.prefix property name in OIC. The system variables {BC} - Batch Code and {BN}- Batch Number are not needed.
• filePath: Give the path name to the object storage where the file will be stored.
Example path:
file-storage://OS-APP/Int-Export for object storage
or
file path: temp/ for ftp
For more information, see the Object Storage Setup Guide 19B at https://docs.oracle.com/cd/F20155_01/index.htm.
Note: When these processes are scheduled to run automatically at a preset time, make sure to have coordinated this timing with the timing of other actions done by Oracle ERP Financial Cloud for General Ledger and Accounts Payable and the integration product. Alternatively, use the standard user interface within Oracle Utilities Customer Cloud Service to run these batch processes manually.
Accounts Payable Extract for Oracle ERP Financial Cloud Batch Process
• After both GLASSIGN and GLS processes have run successfully, schedule the C1-APFCX batch processes to create the AP extract file. Some of the batch parameters are already defaulted. Make sure to define the follwoing parameters:
• source: Indicates the source of the accounts payable request. This value must be a valid value in Payables Lookup, Type= Source in Oracle ERP Financial Cloud. Each external system should be defined as a source in Oracle ERP Financial Cloud.
Example: CCS
• paymentMethod: The value should always be CCB_CHECK. This value is used in the AP Data integration processes as a filtering criteria to determine the AP request came from Oracle Utilities Customer Cloud Service.
• fileName: Name of the AP extract file.
Note: The extract file name defined here should be defined in the property name apreq.extract.filename.prefix of the CCSERPFIN_ConfigProps in Oracle Integration Cloud.
Example filename: APEXTRACTFILE_{BC}_{BN}.csv. Only the APEXTRACTFILE part is defined in apreq.extract.filename.prefix property name in Oracle Integration Cloud. The system variables {BC} - Batch Code and {BN}- Batch Number are not needed.
Example path:
or
