Configuring Admin Data in Oracle Utilities Digital Asset Cloud Service
This section describes the admin data setup in Oracle Utilities Digital Asset Cloud Service related to the integration. The Admin menus can be configured to be grouped alphabetically or by functional groups. The descriptions that follow will include both groupings.
Master Configuration
This section describes the master configuration details for the integration. The following Master Configurations can be found from the Admin menu > [M or General] > Master Configuration:
• Digital Asset Integration Master Configuration
The Digital Asset master configuration is used for synchronizing digital asset customer information to Oracle Utilities Analytics Insights.
Update the Digital Asset Integration Master Configuration created for DACS-DERMS Integration.
Update the Digital Asset Integration master configuration by populating the DataRaker Integration Parameters section with the following data:
• Default Batch Control for Extract: X1-DACEX (Digital Asset Customer Extract for DataRaker)
• Program Subscription Types Eligible for Sync: Configure one or more program subscription types that are eligible for sync to Oracle Utilities Analytics Insights.
Head End System
Create a new or update an existing head end system for each external energy aggregator interfaced to Oracle Utilities Live Energy Connect.
To create a head end system:
1. In the Admin menu navigate to [H or Digital Asset Management] > Head End System > Add.
2. Enter a unique head end system and its description.
3. Specify the external system created for Oracle Utilities Grid Edge Distributed Energy Resources Management System.
4. Add a processing method for processing role Device Status Check. On the processing method, set the following:
• Default Business Object: X1-CtrlDvcStatusCheckComm (Controllable Device - Device Status Check)
• Default Outbound Message Type: Controllable Device Status Check
Activity Type
Create a new or update an existing activity type for the Controllable Device Status Check activity.
To create an activity type:
1. In the Admin menu, navigate to [A or Communication].
2. Add or edit the Controllable Device Status Check activity and its description. Refer to the embedded help for more information.
Business Flag Type
Create a new or update an existing Business Flag Type for the KWH Avoided activity.
To create a Business Flag type:
1. In the Admin menu, navigate to [B or Integration].
2. Add or edit the Standard Name for kWh Avoided.
3. Add or edit the Related Transactional BO for kWh Avoided Business Flag.
4. Add or edit the Status.
5. Add or edit the Description.
6. Add or edit the UOM.
7. Add or edit the TOU.
8. Add or edit the SQI.
9. Add or edit the Interval Size.
Communication Type
Create a new or update an existing communication type for the following Communication Types:
• Controllable Device: Device Status Check
• Controllable Device: Device Status Check Response
To create a communication type:
1. In the Admin menu navigate to [C or Communication Type].
2. Enter a unique communication type and its description. Refer to the embedded help for more information.
Service Task Type
Create a new or update an existing service task type for the following Service Task Type Business Objects:
• Digital Asset Enrollment Request Task Type
• Digital Asset Unenrollment Request Task Type
To create a service task type:
1. In the Admin menu navigate to [S or General].
2. Enter a unique Service Task Type and its Description. Refer to the embedded help for more information.
Sync Request Process
The Sync Request Process is used to synchronize customer enrollment and unenrollment data from Oracle Utilities Digital Asset Cloud Service to Oracle Utilities Analytics Insights. Maintenance Object - Audit algorithms are responsible for instantiating subscription-based sync request records.
To configure a Maintenance Object:
1. In the Admin menu, navigate to [M or Database] > Maintenance Object > Search.
2. Navigate to the following Maintenance Objects and configure the following:
• Usage Subscription (D1-US)
a. Under the Maintenance Object - Options tab, add the “Sync Request BO” MO Option with an option value “X1-DRDigitalAssetCustSync (DataRaker Digital Asset Customer Sync Request)”.
b. Plug in the F1-GCHG-CDCP (Generic Change Data Capture) MO audit algorithm. When a change is detected on a program subscription, this algorithm is responsible for instantiating the sync request.
• Contact (D1-CONTACT): Plug in the X1-CNTCDCDA (Contact Change Data Capture (Digital Asset Subscription Based)) MO audit algorithm. When a change is detected on a contact associated to an eligible program subscription, this algorithm is responsible for instantiating the sync request.
• Device (D1-DEVICE): Plug in the X1-DVCCDCDA (Device Change Data Capture (Digital Asset Subscription Based)) MO audit algorithm. When a change is detected on a controllable device associated to an eligible program subscription, this algorithm is responsible for instantiating the sync request.
• Service Point (D1-SP): Plug in the X1-LOCCDCDA (Location Change Data Capture (Digital Asset Subscription Based)) MO audit algorithm. When a change is detected on a device location associated to an eligible program subscription, this algorithm is responsible for instantiating the sync request.
Scheduling Batch Jobs
Run the following Oracle Utilities Digital Asset Cloud Service Batch Processes:
Enrollment Sync Related Batch Processes
These are the batch processes to run to process the initial and incremental sync request and send the enrollments out as a file from Oracle Utilities Digital Asset Cloud Service.
• F1-SYNRQ - Sync Request Monitor Process
• X1-DACIL - DataRaker Digital Asset Customer Sync Initial Load
• X1-DACEX - Digital Asset Customer Extract for DataRaker
The parameters for this batch process are the following:
Kwh Avoided Upload Batch Process
This is the batch process to calculate and send out the device score to Oracle Utilities Grid Edge Distributed Energy Resources Management System. Schedule the corresponding batch jobs in the order they are listed:
