Type of error | Action | Notification Type | Retry |
Technical Fault Example: Source FTP or Source Object Storage is not accessible. | Process Stop | Error Email | Next scheduled run will pick up the files from the DACS source content server or manually run the OIC process. |
Partial Processing Example: Network connection Issue. OUAI Object Storage not accessible. | Process Stop | Error Email Process Complete Email (includes list of files not transferred) | Next scheduled run will pick up the files not transferred from DACS source content server or manually run the OIC process. |
Business Fault For each record processing in OUAI, it will return a positive/negative acknowledgment in the Ack flow. | Handled by the Enrollment Ack flow | Fix data in DACS or OUAI. Resend message from DACS. |
Technical or Remote Fault Example: OUAI Object Storage is not accessible. | Process Stop | Error Email | Rerun or schedule the integration process |
Technical Fault Example: DACS returns Status 401 or 500 | Process Stop | Error Email | Integration fix: Rerun or reschedule the integration process. |
Technical Fault Example: DACS returns Status 400 | Process Continue | N/A | DACS throws 400 error when a duplicate request is found with syncrequestid. OIC will suppress this kind of error as this has already been synchronizised from OUAI to DACS. |
Technical or Remote Fault Example: OUAI Object Storage is not accessible. | • Send FAILURE ackType to DERMS • Process Stop | Error Email | Resend message from DERMS |
Business Fault | N/A | None OUAI handles the business errors. |
Business Fault | N/A | Error Email | None OUAI handles the business errors. |
Technical Fault (DACS returns Status 400) | Process Continue | N/A | DACS throws 400 error when a duplicate request is found with syncrequestid. OIC will suppress this kind of error as this has already been synchronized from OUAI to DACS. |
