Forms and Plugins
Plugins are used to make changes to screen and data based on their type and status of target and parent object. They are also used to enter measurements, record time/materials/equipment used while completing an activity, populate service history information, install/replace/remove/attach/exchange of assets, viewing asset attributes, using truck inventories and validate completion information before sending the information to verify if the message is accepted by Oracle Utilities Work and Asset Cloud Service.
Plug-ins in Oracle Field Service perform actions not found in the standard solution. They appear as selectable links on the application. They open a new window, tab, or frame in a browser where an external HTML5 application is executed.
For more information on Oracle Field Service plugin framework, refer to latest Oracle Field Service documentation at:
Each plugin contains a JavaScript file that has the main business logic required for functionality of the plugin. The data required for each plugin is available through the properties that are added for the plugin. XML data obtained through properties is parsed and appropriate XSL is applied to it to render each UI.
Measurement Plugin
Measurements manage the asset operational and runtime data collected and tracked for assets. Asset measurements include mileage, hours of uptime, number of start-stops, and more.
Since they almost entirely depend on the usage of the related asset, readings cannot be calculated or predicted accurately by the system. Instead, readings must be collected and entered into the system, either manually by a user or imported as the result of activity completion.
To import plugins:
1. Login to Oracle Field Service with valid credentials.
2. Click the hamburger menu icon (icon with three horizontal lines) on the upper-left corner of the Home page.
3. Navigate to Configuration > Displays > Forms and Plugins.
4. From the Import drop-down list, select Plugins.
5. Click the Drag and Drop field to select measurement plugin. Click Validate.
Oracle Field Service validates the plugin and the number of valid items should be 1.
6. Click Import. Make sure the values in Number of valid items and Number of not valid items are ‘1’ and ‘0’ respectively.
After the successful import of the plugin, Oracle Field Service displays the details as shown below.
7. Make sure the Available Properties tab is populated with all properties.Available Properties section where the set of properties appear.
Resource Usage Plugin
Timesheets are used to record the amount of time that workers (labor resources) spend on activities or work orders. Once charges are entered, processing allows employees to receive proper compensation for their work and labor charges are applied to the appropriate cost buckets.
Generally, only each individual and the person designated as the supervisor on that individual's crew can access timesheet information for that person. Supervisor can enter individual timesheet for himself if the secure parameter "ofsc_sup_in_team " is set to 'true/yes'.
To import the plugin:
1. Repeat steps 1 to 5 from Measurement Plugin.
2. Click the Import drop-down list and select Plugins to import the resource usage plugin provided in the package.Detail of the Forms and Plugins page where the Import drop-down menu is (extreme right, next to Export).
3. Select the resource plugin and enter the following details under the secure parameters:
• oic_url: https://OIC_host:OIC_port/ic/api/integration/v2/flows/rest/project/OUTL-BA-WACS_OFSC/OUTL-BA-OFSC_WACS_RES_USAGE_SEND/1.0/resourceUsage
• oic_uname/oic_password: OIC username/password
Oracle Field Service users should configure the following:
• ofsc_uname: clientID@instance ID
• ofsc_password: client secret key
• ofsc_bucket: External ID of bucket configured in your environment
• ofsc_hostname: [api_path]
Example: https://<site address>.<domainName>
• ofsc_sup_in_team: true/false or yes/noResource plugin options with text fields to be populated by the user.
Make sure the Available Properties tab is populated with properties as shown below.Available Properties section where the set of properties appear.
Note: For all plugins to which “ofsc_siteAddress” has to be configured under secure parameters, it is replaced with “ofsc_hostname”. While configuring secure parameters for plugins, please note that “ofsc_siteAddress” parameter is removed and a new parameter “ofsc_hostname” is created.
Service History Plugin
Service history is information about some type of service or maintenance performed on an asset. Information typically associated with service history include record inspection feedback, pass/fail details, downtime, parts failure information, maintenance or service logs, or other information regarding service on the asset.
2. Click the Import drop-down list and select Plugins to import the service history plugin provided in the package.Detail of the Forms and Plugins page where the Import drop-down menu is (extreme right, next to Export).
3. Make sure the Available Properties tab is populated with the properties as shown below.Available Properties section where the set of properties appear.Available Properties section where the set of properties appear.
Validate Completion Plugin
This plugin helps crew to validate the eligibility to the activity to complete. If the activity is not yet eligible, the plugin displays corresponding error message if the eligibility is success crew navigates to end activity screen to complete the activity.
1. Repeat steps 1 to 5 from the Measurement Plugin section.
2. Click Import Validate Completion Plugin to import the validate completion plugin provided in the package. Detail of the Forms and Plugins page where the Import drop-down menu is (extreme right, next to Export).
3. Select the Validate Completion plugin and enter the following details in the secure parameters:
Example: https://<site address>.<domainName>Shows the secure parameters.
4. Make sure that the Available Properties tab is populated with the properties as shown below.
Available Properties section where the set of properties appear.Available Properties section where the set of properties appear.Available Properties section where the set of properties appear.Available Properties section where the set of properties appear.Available Properties section where the set of properties appear.
Planned Service History Plugin
Planned Service history is information regarding some type of service or maintenance performed on an asset. Information typically associated with service history include record inspection feedback, pass/fail details, downtime, parts failure information, maintenance or service logs, or other information regarding service on the asset.
2. Click the Import drop-down list and select Plugins to import the Planned Service History plugin provided in the package. Detail of the Forms and Plugins page where the Import drop-down menu is (extreme right, next to Export).
3. Select the Planned Service History plugin and enter the following details in the secure parameters:
4. Make sure the Available Properties tab is populated with the properties as shown below.
Asset Component Install Exchange Undo Plugin
Handle operations on Install, Uninstall and Replace actions for the assets and components in a work activity. Information associated with the components used for the assets on completion of the activity is handled.
2. Click the Import drop-down box and select Plugins to import the Asset Component Install Exchange Undo plugin provided in the package.Detail of the Forms and Plugins page where the Import drop-down menu is (extreme right, next to Export).
3. Select the Asset Component Install Exchange Undo plugin and enter the details under the secure parameters:
• oic_url: https://OIC_host:OIC_port/ic/api/integration/v2/flows/rest/project/OUTL-BA-WACS_OFSC/OUTL-BA-OFSC_WACS_ASSET_QUERY/1.0/assetQueryDetails
• ofsc_multiDay_act_lbls: The Activity type of the Multi-Day activity created in OFSC. If there are more than one use '|' separator.
Example: Act1|Act2|Act3
• ofsc_uname: OFSC username - clientID@instanceid (application should have access to all the apis)
• ofsc_password: OFSC password: client secret key
4. Make sure the Available Properties tab is populated with the properties as shown below. Available Properties section where the set of properties appear.Available Properties section where the set of properties appear.Available Properties section where the set of properties appear.
Lock Unlock Activity Plugin
Handle operations lock or unlocking of an activity for a crew so that he can work on it.
2. Click the Import drop-down box and select Plugins to import the Lock Unlock Activity Plugin provided in the package.Detail of the Forms and Plugins page where the Import drop-down menu is (extreme right, next to Export).
3. Make sure the Available Properties tab is populated with properties as shown below.Available Properties section where the set of properties appear.
Pick Up Work Plugin
This plugin helps the crew to create Work order, Work Request of types Asset related or non-Asset related from Oracle Field Service application itself. It can be a follow up to existing activity or a new work which is unrelated pickup.
1. Repeat steps 1 to 5 from the Measurement Plugin section.Detail of the Forms and Plugins page where the Import drop-down menu is (extreme right, next to Export).
2. Select the Pick Up Work plugin and enter the following details under the secure parameters:
• oic_url1: https://OIC_host:OIC_port/ic/api/integration/v2/flows/rest/project/OUTL-BA-WACS_OFSC/OUTL-BA-OFSC_WACS_ASSET_QUERY/1.0/assetQueryDetailsPickup
• groupLabel: OFSC group label
• bucket_for_nonScheduled: External ID of the bucketResource plugin options with text fields to be populated by the user.
• esri_mapLink: Deep link URL to ArcGIS Field Maps
• https://fieldmaps.arcgis.app/?itemID=<gis_map_id> &referenceContext=center&center=
Note: Leave this parameter blank if you are not implementing the ESRI ArcGIS Field Maps integration to Oracle Field Service.
3. To create a follow up work order request in Oracle Field Service, add values to the Request Type property in Oracle Field Service.
a. Navigate to Configurations > Properties and search for Request Type.
b. Edit the Resource Type property. In the Values section, click Add. In the Service Request Type Name field, enter “workRequest” and in the Status field, enter “Active”.
4. Click the Import drop-down box and select Plugins to import the Pick Up Work Plugin provided in the package.Available Properties section where the set of properties appear.Available Properties section where the set of properties appear.
Materials Plugin
This plugin handles the operations related to mobile storerooms in Oracle Field Service including reporting the use of materials. The operations include Use/Undo Use Item, Install/Undo Install Asset, and Attach/Undo Attach component from truck inventories. Oracle Field Service can request an update of a mobile storeroom passing date/time of the last snapshot.
2. After the successful import of plugin, Oracle Field Service displays the details as shown below.Detail of the Forms and Plugins page where the Import drop-down menu is (extreme right, next to Export).
3. Select the Materials plugin and enter the details for the following secure parameters:
• oic_storeroom_sync_url: https://OIC_host:OIC_port/ic/api/integration/v2/flows/rest/project/OUTL-BA-WACS_OFSC/OUTL-BA-OFSC_WACS_STOREROOM_SYNC/1.0/syncStoreroom
• oic_assetQueryDetails_url: https://OIC_host:OIC_port/ic/api/integration/v2/flows/rest/project/OUTL-BA-WACS_OFSC/OUTL-BA-OFSC_WACS_ASSET_QUERY/1.0/assetQueryDetails
• oic_activityUpdate_url: https://OIC_host:OIC_port/ic/api/integration/v2/flows/rest/project/OUTL-BA-WACS_OFSC/OUTL-BA-OFSC_WACS_ACTV_UPDT_PULL/1.0/retrieveUpdates
Example: https://<site address>.<domainName>Resource plugin options with text fields to be populated by the user.
4. Make sure the Available Properties tab is populated with all required properties.Available Properties section where the set of properties appear.Available Properties section where the set of properties appear.Available Properties section where the set of properties appear.
Asset Attribute Plugin
This plugin displays the asset attribute list of an asset in Oracle Field Service. The asset can be in existing, installed or de-installed pool. Asset attributes are characteristic that are recorded for an asset. Only characteristic types with an adhoc and predefined value can be used as asset attributes. Each asset type records which characteristic types can be used for asset attributes for assets of that types.
2. Click the Import drop-down list and select Plugins to import the Asset Attribute plugin provided in the package.Detail of the Forms and Plugins page where the Import drop-down menu is (extreme right, next to Export).
3. Select the Asset Attributes plugin and enter the details for the following secure parameters:
• ofsc_multiDay_act_lbls: Activity Type of the Multi-Day activity created in OFSC. If there are more than one, use the '|' separator
View In Map
This is an external application type plugin and accessed as a web page in a new window or the same window in Oracle Field Service. The plugin is used to navigate to ArcGIS Field Maps from Oracle Field Service through deep link URL.
Note: Please configure this plugin only when you want to implement the ArcGIS Field Maps integration with Oracle Field Service along with the Oracle Utilities Work and Asset Cloud Service integration to Oracle Field Service.
1. Import the plugin into the Oracle Field Service environment.
2. Configure the map URL in the Launch application URL field both in Android and iOS.
Make sure the URL is in the following format:
https://fieldmaps.arcgis.app/?itemID=<gis_map_id>dd&referenceContext=center&center={wam_activity_latitude},{wam_activity_longitude}
