| Type of Error  | Action | Notification Type | Retry |
| External Mobile Control Data service unavailability | •	Process Stop •	The OIC instance is marked as Failed | Technical Error Email | Reschedule execution in OIC |
| Failure in any of the file creation or any other errors | •	Files already in Object Storage remain. •	Collect the error details. •	Process the next file. •	At the end, a summary notification email and, if applicable, a Technical Error Detail email are sent. •	The OIC instance is marked as Failed. | •	Technical Error Email •	Business Notification Email with Summary of Files | Reschedule execution in OIC |
| Invalid Token | •	Process Stop •	The OIC instance is marked as Failed. | Technical Error Email | Reschedule execution in OIC |
| Remote Fault[Application down] | •	Process Stop •	The OIC instance is marked as Failed. | Remote Error Email | Reschedule execution in OIC |
| Business Fault [Bad Request] | •	The error is collected for each record. •	The EXTERNAL_REC_INFO field is not updated and still retains the value of N. •	OIC processing is successful. | Business Error Email with failed records | Fix the relevant issue and reschedule execution in OIC |
| Technical Fault[Xpath or DVM issue] | •	The error is collected for each record. •	The EXTERNAL_REC_INFO field is not updated and still retains the value of N. •	OIC processing is successful. | Business Error Email with errors as attachment | Fix the relevant issue and the next run should successfully process the record. If the records cannot be fixed, update the EXTERNAL_REC_INFO field of the Task layer to Y. |
| Remote Fault[Application down] | •	Process Stop •	The OIC instance is marked as Failed. | Technical Error Email | Reschedule execution in OIC |
| Business Fault [Bad Request] | •	The error is collected for each record. •	OIC processing is successful. | Business Error Email with error details per status when connected to Online ESRI services. | Fix the relevant issue and reschedule execution in OIC |
| Technical Fault[Xpath or DVM issue] | •	Process Stop •	The OIC instance is marked as Failed. •	The OIC instance is marked as Failed. | Technical Error Email | Reschedule execution in OIC. |
| Invalid Token eError while querying or updating/creating ESRIActivities and ActivityAssets on ArcGIS Enterprise server. | •	Process Stop | Business Error | Reschedule execution in OIC |
| Invalid Token error while getting asset attributes for a given gis ID from the asset feature layer published on ArcGIS Enterprise server. | •	Process continues •	The error message is collected, and email will be sent. •	OIC processing is successful. | Business Error | Reschedule execution in OIC |
| Business Fault while create/update record in ArcGIS. Example: Foreign key constraints, Bad Request | •	Error is thrown and process stops. •	The flow will not continue further if the error occurred during the activity create/update invocation. It will not insert the asset records if the activity create/update fails. •	The error is handled in the fault handler. •	OIC processing is successful. | Business Error Email with error details will be sent. | Fix the relevant issue and reschedule execution in OIC. |
| Technical Fault [Xpath or DVM issue] | •	Process Stop •	The OIC instance is marked as Failed. •	The OIC instance is marked as Failed. | Technical Error Email | Reschedule execution in OIC |
| Remote Fault [ArcGIS or OFS Application down] | •	Process Stop •	The fault is thrown. •	The fault will be handled in the fault handler section of the flow. •	The OIC instance is marked as Failed. | Technical Error Email | Reschedule execution in OIC |
