New Features Summary
The following enhancements are included in this release:
Activities Sync - (Asset Search) Optimizations
The asset search configuration in Oracle Integration Cloud lookups has been optimized by removing a strict asset type dependency and leveraging the feature layer IDs instead. This supports scenarios where a single asset type can be found in multiple feature layers.
Error Notification Improvements
Additional improvements were made to both technical and functional error notifications for better clarity and issue resolution.
