Configuring the Sync Request Process
The Sync Request process is used to synchronize customer data from Oracle Utilities Customer to Meter to Oracle Utilities Network Management System.
For Oracle Utilities Customer Care and Billing and Oracle Utilities Meter Data Management (separate instance) implementations, this is configured in Oracle Utilities Meter Data Management.
Batch Code
This is the batch process to run the synchronization request. It is a generic batch process that is used for different synchronization processes. It has a couple of parameters that can be used to control which synchronization request BOs to process.
Batch
Description
F1-SYNRQ
Sync Request Monitor Process
Batch Parameters
Parameter Description
Value
maintenanceObject
Sync Request maintenance object
F1-SYNC REQ
This is the defaulted value.
isRestrictedByBatchCode
The ‘true’ value restricts processing to sync requests whose current state is linked to this batch code.
restrictToBusinessObject
Enter a business object code here to limit the process to sync requests linked to this business object.
D1-NMSSP CustomerSyncRequest
Populate this value to run only the NMS customer sync request.
restrictToBOStatus
Enter a status code here to limit the process to sync requests in this state.
PENDING
Populate this value to only process a sync request in ‘Pending’ status.
This batch process is used to run the initial load synchronization request. It has a couple of parameters that can be used to control which synchronization request BOs to process.
Batch
Description
D1-NMSSP
NMS SP Customer Sync Initial Load
Batch Parameters
Value
syncRequestMO
Maintenance Object
D1-SP
syncRequestBO
D1-NMSSPCustomer
SyncRequest
filterAlgorithm
Enter a filter algorithm here to limit the process to sync requests that should be sent to Oracle Utilities Network Management System.
D1-NMSSPCustomerSync
Request
This algorithm filters for eligible service point types as defined in the NMS Sync Integration Master Configuration.
MO Algorithms
Configure the MO Audit algorithms. MO Audit algorithms contain the logic to instantiate a sync request (as long as one does not already exist in the initial state for the MO-Primary Keys combination). A generic algorithm F1-GCHG-CDCP comes with the base product and is plugged in on MOs that need to instantiate sync requests for the same MO. This algorithm instantiates the BOs defined in the Sync Request BO MO Option. For MOs that need a sync request instantiated for a different MO (for example: changes to the Person or Account MO need to be communicated via an SP sync request) need unique algorithms that contain this logic.
For more information, refer to the Maintenance Objects section.
Algorithm Type
Description
D1-CUSCDCSP
This algorithm instantiates SP-based sync request whenever a change to the Contact MO is detected (updating a person record in CCS/C2M triggers an internal sync to the contact record, which in turn will trigger this audit algorithm).
Define the D1-NMSSPCustomerSyncRequest sync request BO to be instantiated in the algorithm's parameters.
D1-USCDCSP
This algorithm instantiates SP-based sync request whenever a change to the Usage Subscription MO is detected (updating a SA record in CCS/C2M triggers an internal sync to the usage subscription record, which in turn will trigger this audit algorithm).
Define the D1- NMSSPCustomerSyncRequest sync request BO to be instantiated in the algorithm's parameters.
D1-SPIE-CDCP
This algorithm instantiates SP-based sync request whenever a change to the Install Event MO is detected.
D1-SPDV-CDCP
This algorithm instantiates SP-based sync request whenever a change to the Device MO is detected.
Maintenance Objects
Maintenance Objects
Description
D1-CONTACT
Specify the MO Audit algorithm configured in the MO Algorithms section.
D1-US
D1-INSTLEVT
D1-DEVICE
D1-SP
Specify the generic MO Audit algorithm F1-GCHG-CDCP. Also, specify the D1-NMSSPCustomerSyncRequest BO in the Sync Request BO MO Option.
Business Objects
Business Object
Description
D1- NMSSPCustomer SyncRequest
This business object defines the behavior of the outbound sync request for NMS. It contains the schema elements monitored and synchronized to NMS.
The following must be configured and defined on the NMS Sync Integration master configuration as they are necessary to create the outbound sync request:
• Outbound Message Type: This contains a reference to the outbound message BO to use. The base package includes BO D1- NMSSPCustomerSyncReqOutMsg for the NMS SP Sync. Refer to the Defining Outbound Message Types section in the user documentation for more information.
• External System: This contains the reference to the outbound message type and its corresponding configuration for communicating with the external system. Refer to the External Systems section in the user documentation for more information.
• Specify the pre-processing algorithm configured in the MO Algorithms section.
• Specify the time out algorithm as a monitor algorithm on the Awaiting Acknowledgement state for this BO.
• Specify the To Do creation algorithm on the Error state for this BO. Depending on the technology used to communicate the sync request to the external system, you may need to create your own enter algorithm and plug it into the Send Request state.
For more information about the sync request process, the business objects, maintenance objects, and other components use for this process, see the Data Synchronization section in the Oracle Utilities Framework Administrative User Guide.
