Message Senders
This section provides the message sender configuration details in Oracle Utilities Network Management System and Oracle Utilities Customer Cloud Service.
Configuring Message Sender in Oracle Utilities Customer Cloud Service
Create a new message sender for each integration service initiated from Oracle Utilities Customer Cloud Service (Customer Data Sync, Submit Truble Call, Job History Query and Planned Outages Query).
To create a message sender:
1. Navigate to Admin > Integration > Message Sender from the menu or from the Search bar.
2. Enter a unique message sender and its description.
3. Populate the following values:
• Message Sender: Message Sender Name
• Description: Short description about the message sender.
• Invocation Type: Real-time
• Message Class: SOAPSNDR
• Active: Select the checkbox.
• MSG Encoding: UTF-8 message encoding
4. Select the Context tab and set values (click +) for the following context types:
• HTTP Header: SOAPAction:”” <HTTP Login User: User ID to access the Oracle Integration Cloud (OIC) flow>
• HTTP Password: Password to access the Oracle Integration Cloud flow.
• HTTP Method (POST/GET): POST
• HTTP Timeout: 60
• HTTP Trasnport Method: SendReceive
• HTTP URL 1: Set the Activated Integration end point URL by removing ?wsdl from the URL.
If the URL value does not fit, use the additional HTTP URL types to set the complete URL.
• Message Namespace URI: Provide the namespace of the schema in the respective integration process.
Important! Make sure the namespace does not include any extra spaces. Copy the namespaces into Notepad to check for any extra spaces.
• SOAP Insert Timestamp (Y/N): Y
• Sender Security Type: TEXT
Message sender configuration for integration services
Message Sender
Description
HTTP Header
HTTP URL
NMS-CDSOIC
NMS Customer Data Sync from OIC
http://ouaf.oracle.com/webservices/outbound/NMS_NMS-SPSYNC
SOAPAction:"NMS_NMS-SPSYNC"
https://ewgen3instance1-id09o3eaz21u-ia.integration.us-ashburn-1.ocp.oraclecloud.com
NMS-QCH-OIC
NMS Call History Query from OICNMS-QJHOIC
http://ouaf.oracle.com/outbound/NMS_C1-NMSCAHST
SOAPAction:"NMS_C1-NMSCALHST"
https://ewgen3instance1-id09o3eaz21u-ia.integration.us-ashburn-1.ocp.oraclecloud.com/ic/ws/integration/v2/flows/oracleutilities/project/OUTL-BA-CCS_NMS/OUTL-BA-CCS_NMS_CALL_HISTORY/1.0/
NMS-QJHOIC
NMS Job History Query from OIC
http://ouaf.oracle.com/outbound/NMS_C1-NMSJOBHST
SOAPAction:"NMS_C1-NMSJOBHST"
https://ewgen3instance1-id09o3eaz21u-ia.integration.us-ashburn-1.ocp.oraclecloud.com/ic/ws/integration/v2/flows/oracleutilities/project/OUTL-BA-CCS_NMS/OUTL-BA-CCS_NMS_JOB_HISTORY/1.0/
NMS-QPO-OIC
NMS Query Planned Outage Query from OIC
SOAPAction:"NMS_C1-NMSPLNOUT"
https://ewgen3instance1-id09o3eaz21u-ia.integration.us-ashburn-1.ocp.oraclecloud.com/ic/ws/integration/v2/flows/oracleutilities/project/OU_CCS_NMS/OUTL-BA-CCS_NMS_PLANNED_OUTAGES/1.0/
NMS-SC-OIC
NMS Outage Call Processing Submit Calls from OIC
http://ouaf.oracle.com/outbound/C1-OutageCallOutboundMsg
SOAPAction:"NMS_C1-NMSOUTCAL"
https://ewgen3instance1-id09o3eaz21u-ia.integration.us-ashburn-1.ocp.oraclecloud.com/ic/ws/integration/v2/flows/oracleutilities/project/OU_CCS_NMS/OUTL-BA-CCS_NMS_SUBMIT_CALLS/1.0/
