Setting Up the Integration Pack
The following sections describe how to configure the integration pack to meet the requirements for the integration.
To configure the integration you must complete the following:
Setting Up Configuration Properties
Various configurations that apply to the entire integration and specific processes for the integration services are stored in the OUTL-BRT-CCS_NMS_ConfigProps lookups section. These configurations hold several configurable values that are picked up by the integration at runtime to:
Set the default values to be used in the integration.
Activate error handling.
Note: Whenever the OUTL-BRT-CCS_NMS_ConfigProps lookup is updated, all integrations must be restarted by deactivating and reactivating integration.
Setting Up Lookup Value Maps
Lookups is a feature of Oracle Integration Cloud which maps codes and other static values across applications.
Example: "FOOT" and "FT" or "US" and "USA"
The lookup values are static in nature, though administrators can add additional maps as needed.
