Oracle Integration Cloud
This section focuses on the monitoring Oracle Integration Cloud and troubleshooting any issues that occur during the integration activation.
Monitoring Integration Flows
Integration flows are monitored using the following:
•	Project (for project based instances)
•	Observability (for non project based instances)
To monitor the integration flows within a project:
1.	Login to Oracle Integration Cloud.
2.	Click Projects. On the navigation pane, click the relevant project.
3.	Navigate to the Observe menu.
4.	You can review:
a.	Integrations to view the count of various statuses of instances created per integration flows.
b.	Instances to view instances of integrations of the project.
c.	Future runs to view all the runs scheduled or started for scheduled integrations.
d.	Audit to view and download design-time audit logs.
To monitor integration flows from the Oracle Integration Cloud Observability menu option:
2.	Click Observability on the menu.
3.	Select any of the following as required:
•	Dashboards: To monitor the complete dashboard of integration. Get at-a-glance information about the number and status of your projects, integrations, connections and more.
•	Integrations: The Monitor integrations page lets you view the message processing status of your running integrations. It shows the number of messages that are:
•	Received and processed
•	Successful, in error, or aborted, and errors have occurred
•	Aborted
•	Instances: To filter and track the status of integration instances and show the flow trace/activity stream of the integration.
•	Error: To manage errors in Oracle Integrations. Resubmit failed instances, discard failed instances, view message recovery status, and view basic and detailed error messages.
Troubleshooting
To troubleshoot errors in the workflow through the generated instances, you can set tracing level to DEBUG to generate detailed logs.
To enable DEBUG:
1.	Select Configure Activation and then select the Tracing Level to be 'DEBUG'.
2.	Run the integration and check the activity stream which now will include the runtime log details of the flow.
3.	If an activation fails, the Integrations page displays an error.
	Sample cases:
•	While activating the integration, if there are any connectivity errors, make sure to trigger the connection, test it, refresh the metadata, and then activate the integration.
•	For Oracle Utilities Customer Cloud Service initiated integration flows activated for the first time, make sure that theOracle Utilities Network Management System catalog is configured accurately. All external systems and inbound web services used by the integration are defined in the catalog.
