Oracle Integration Cloud
This section focuses on the monitoring Oracle Integration Cloud and troubleshooting any issues that occur during the integration activation.
Monitoring Integration Flows
Integration flows are monitored using the following:
• Project (for project-based integration instances)
• Observability (for nonproject-based integration instances)
To monitor the integration flows within a project:
1. Log in to Oracle Integration Cloud.
2. Click Projects.
3. Select the relevant project from the navigation pane.
4. Navigate to the Observe menu.
5. Check one of the following:
• Integrations: For viewing the counts of various status of instances created per integration flows.
• Instances: For viewing instances of integrations of the project.
• Future Runs: For viewing all scheduled runs or started runs for scheduled integrations.
• Audit: For viewing and downloading design-time audit logs.
Refer to the Monitor the Message Processing Status of Integrations in Projects section of Using Integrations in Oracle Integration 3 for more information.
To monitor the integration flows from the Oracle Integration Cloud Observability menu option:
2. From the navigation pane, click Observability.
3. Check one of the following:
• Dashboards: Use to monitor the complete dashboard of integration. Get at-a-glance information about the number and status of projects, integrations, connections, and more.
• Integrations: The Monitor Integrations page lets you view the message processing status of running integrations. The page shows the number of messages received and processed. The page shows the number of successful, erroneous, or aborted messages.
• Instances: Use to filter and track the status of integration instances, and view track or activity streams of the integration.
• Errors: Use to manage errors in Oracle Integrations, resubmit failed instances, discard failed instances, view message recovery status, and view basic and detailed error messages.
Refer to the Explore the Navigation Pane section of Getting Started with Oracle Integration 3 for more information.
Troubleshooting
To troubleshoot workflow errors through generated instances, set the tracing level to DEBUG to generate detailed logs.
To enable DEBUG, complete these steps:
1. Select Configure Activation and select the DEBUG tracing level.
2. Run the integration.
3. Check the activity stream for runtime log details of the flow.
• If an activation fails, the Integrations page displays an error. A few sample cases are as follows:
• For any connectivity errors while activating the integration, make sure the trigger connection is successful. Test the connection and refresh the metadata, and then activate the integration.
• If the integration (Oracle Utilities Network Management System initiated flows) is activated for the first time, make sure the Oracle Utilities Network Management System catalog is configured accurately.
