Configuring Connections in Oracle Integration Cloud
After the project is imported and verified, the respective connections have to be configured.
This section describes the procedure to set up the following connections:
Configuring Oracle Utilities SOAP UCM Gen Svc for WACS-FPRC Connection
This connection is used to communicate with Oracle Universal Content Management using the SOAP adapter.
To configure the Oracle Utilities SOAP UCM Gen Svc for WACS-FPRC connection:
1. Specify the WSDL URL.
The Oracle UCM Web Service follows this format: https://{ERP Cloud host}/idcws/GenericSoapPort?WSDL
2. From the Security Policy drop-down list, select Basic Authentication.
3. Provide Username and Password to connect to Oracle UCM.
4. Click Test at the upper-right corner.
5. After the connection is tested successfully, click Save.
Configuring Oracle Utilities REST WACS for WACS-FPRC Connection
This connection is used to communicate with Oracle Utilities Work and Asset Cloud Service using the Oracle Utilities Adapter.
To configure the Oracle Utilities REST WACS for WACS-FPRC connection:
1. Specify the Oracle Utilities Work and Asset Cloud Service REST web catalog in the catalogURL section.
The REST Catalog URL follows this format: https://{host}:{port}/{tenant}/{domain}/{appName}/rest/openapi/iws/catalog
2. In the Security Policy drop-down list, select Basic Authentication.
3. Provide Username and Password to connect to Oracle Utilities Work and Asset Cloud Service.
Configuring Oracle Utilities REST for WACS-FPRC Connection
This connection is used as a REST trigger.
To configure the REST for WACS-FPRC connection:
1. In the Security Policy section, select OAuth2.0 or Basic Authentication.
2. Click Test.
3. After the connection is tested successfully, click Save.
Configuring Oracle Utilities ERP Cloud for WACS-FPRC Connection
This connection is used to communicate with Oracle ERP Fusion Cloud application using the Oracle ERP Cloud Adapter.
To configure the Oracle ERP Financial Cloud for WACS-FPRC connection:
1. Enter the ERP Cloud Host URL.
Example: https://ERP_domain_name.fa.DC.oraclecloud.com
Note: The Oracle ERP Cloud host name can easily be derived from the Oracle ERP Cloud login URL.
2. In the Security Policy section, select Username Password Token.
3. Enter the Username and Password to connect to Oracle ERP Financial Cloud.
4. Click Test.
Configuring Oracle Utilities REST ERP for WACS-FPRC Connection
This connection is used to communicate with Oracle ERP REST API using the REST Adapter.
To configure the Oracle Utilities REST ERP for WACS-FPRC connection:
1. Specify the Oracle ERP Cloud URL in the Connection URL section format.
Example: https://ERP_domain_name.fa.DC.oraclecloud.com:443
3. Provide Username and Password to connect to Oracle ERP.
