Configuring Connections in Oracle Integration Cloud
After the projects are imported and verified, the respective connections must be configured.
This section describes the procedure to set up the following connections:
Configuring Oracle Utilities SOAP WACS for WACS-OFSC Connection
This connection is used to communicate with Oracle Utilities Work and Asset Cloud Service using the Oracle Utilities adapter.
To configure the Oracle Utilities SOAP WACS for WACS-OFSC connection:
1. Add the Oracle Utilities Work and Asset applications catalog to the CatalogURL field on the Oracle Integration Cloud Connection page.
In the on-premises applications, make sure that the catalog is in the following format:
http(s)://<WAM_HOST>:<WAM_PORT>/<ContextRoot>/webservices/builtin/ServiceCatalog?wsdl
If you are using Oracle Utilities Work and Asset Cloud Service, the format should be: https://{host}:{port}/{tenant}/{domain}/{appName}/soap/api/ iws/ServiceCatalog?WSDL
2. On the Security policy tab, select the respective security policy from the drop-down list.
3. If you are using Basic Authentication policy in the Message Sender configured in Oracle Utilities Work and Asset Cloud Service:
a. Select Basic Authentication from the drop-down list.
b. Enter the username and password authenticating the catalog configured for the application.
4. If the security policy used is OAuth Client Credentials in the Message Sender configured in Oracle Utilities Work and Asset Cloud Service:
a. Select OAuth Client Credentials from the options.
b. Make sure the OAuth client configuration is completed in Oracle Identity Cloud Service and have the respective OAuth Credentials details for your application.
Access Token URI: The URL from which to obtain the access token for authenticating application catalog.
Client ID: The client identifier issued to the client application during registration process.
Client Secret: The client secret of the client application.
Scope: The scope of the client application
For on-premises: https://host:port/ouaf/*
For cloud: ugbucs-<product>-<environment>-<domain_name>/*
Example: ugbucs-WAC-DEV01-Z915U1/*
Auth Request Media Type: This is an optional parameter that can be kept blank.
Client Authentication: This is an optional parameter. By default, it takes the Send client credentials as basic auth header.
Send client credentials as basic auth header: Pass the client ID and client secret in the header as basic authentication.
Send client credentials in body: Pass the client ID and client secret in the body as form fields.
5. In case of Oracle Utilities Work and Asset on-premises, configure the agent in the connection.
a. In the Agent Group section, click Configure Agents.
b. Select the agent group from the list created in Creating an Agent Group.
6. Click Test at the upper-right corner to test the connection.
7. After the connection is tested successfully, click Save.
Configuring Oracle Utilities OFSC for WACS-OFSC Connection
This connection is used to communicate with Oracle Field Service using the Oracle Field Service adapter.
Configure the Oracle Utilities OFSC for WACS-OFSC connection with the required details:
1. Enter the API URL in the Field Service Cloud API URL field on the Oracle Integration Cloud Connection page.
2. Enter the Instance ID of the Oracle Field Service application.
3. From the Security Policy drop-down list, select Client Credentials.
Note: Please note that Basic Authentication is deprecated in this release.
4. Provide ClientID and Client Secret (you can retrieve them from the Oracle Field Service environment).
Note: For more information, refer to the Oracle Field Service documentation.
5. Click Test at the upper-right corner to test the connection.
6. After the connection is tested successfully, click Save.
Configuring Oracle Utilities REST for WACS-OFSC Connection
This connection is used to communicate with Oracle Field Service using the REST adapter. It is used in the Resource usage flows (Oracle Field Service initiated flows triggered by Oracle Field Service).
Edit the Oracle Utilities REST for WACS-OFSC connection and test it to make sure it is successful. Click Save.
Configuring Oracle Utilities REST OFSC for WACS-OFSC Connection
This connection is used to communicate with the OFSC API using the REST adapter. It is used in the Admin sync flow inbound to Oracle Field Service.
Configure the Oracle Utilities REST OFSC for WACS-OFSC connection with required details:
1. On the Connection page, from the Connection Type drop-down list, select REST API Base URL.
2. Do not configure the TLS version.
3. Enter “https://<ofs-instance>.fs.ocs.oraclecloud.com/rest” in the Connection URL field.
4. From the Security Policy drop-down list, select Basic Authentication.
5. Enter the user name and password authenticating the connection URL configured for Oracle Field Service. Click Test to test the connection.
