Accelerator Package
The accelerator package includes various user types, properties, and plugins. This document explains the configurations for other elements such as activity types, work zones, work skills, work conditions and outbound channel.
The package helps customers to configure and set up Oracle Field Service to be used in the Oracle Utilities Work and Asset Cloud Service integration to Oracle Field Service as the package contains only Oracle Utilities Work and Asset Cloud Service and Oracle Integration Cloud configuration files and instructions. It is used in addition to the integration package that provides a complete end-to-end set up for the integration.
The contents of the package are:
• User Types: Define layouts and UI screens. Refer to the User Types section for more details.
• Properties: Create layouts and mapping. Refer to the Properties section for more information.
• Plugins: The plugins that are part of this integration are measurements, service history, planned service history, resource usage, assetComponentInstallExchangeUndo, pick up work, lock unlock, materials, asset attributes, asset history, and validate completion. Refer to the Forms and Plugins section for more information.
