Merging the Oracle Field Service Customizations
After the successful upgrade, add the following customizations:
Properties
Re-import the properties that are not part of admin synchronization. The data will be synchronized to the admin sync properties.
User Type
Add your customization back to the user type file on top of the latest code line.
To add customization from UI:
1. Navigate to the UI section of the user type file.
2. Add the customization manually.
To add customization by editing the user type file directly:
1. Open the user type file in a text editor and search for the section where the customization should be added.
2. Copy the customization from the old backup file and paste it into the latest user type section.
3. Repeat step 2 for those sections where customizations can be added.
For more details about Oracle Field Service accelerator customization, refer to the Customizations chapter in Oracle Field Service Configurations for Oracle Utilities Work and Asset Cloud Service Integration to Oracle Field Service Setup Guide included in this release. The documentation is available on Oracle Help Center at: https://docs.oracle.com/en/industries/energy-water/integrations-index.html
