Oracle Integration Cloud
This section focuses on the monitoring Oracle Integration Cloud and troubleshooting any issues that occur during the integration activation.
Monitoring Integration Flows
Integration flows are monitored using the following:
• Project (for project based instances)
• Observability (for non project based instances)
To monitor the integration flows from the Oracle Integration Cloud dashboard:
1. Login to Oracle Integration Cloud.
2. Click Projects. On the navigation pane, click the relevant project.
3. Navigate to the Observe menu.
4. You can check:
a. Integrations to view the counts of various status of instances created per integration flows.
b. Instances to see instances of integrations of the project.
c. Future runs to see all the runs scheduled or started for scheduled integrations.
d. Audit to view and download design-time audit logs.
To monitor integration flows outside the project using Oracle Integration Cloud Observability menu option:
2. Click Observability on the menu.
3. Select any of the following as required:
• Dashboards: To monitor the complete integration information. Get at-a-glance information about the number and status of your projects, integrations, connections and more.
• Integrations: The Monitor integrations page lets you view the message processing status of your running integrations. It shows how many messages have been received and processed and how many messages are successful, in error or aborted and errors have occurred, and how many messages have been aborted.
• Instances: To filter and track the status of integration instances and show the flow trace/activity stream of the integration.
• Error: To manage errors in Oracle Integrations. Resubmit the failed instances, discard the failed instances, view the message recovery status, and view the basic and detailed error messages.
For more information, refer to the Navigate and Explore section in Getting Started with Oracle Integration 3.
Troubleshooting
To troubleshoot the errors in the workflow through the generated instances, you can set tracing level to DEBUG to generate detailed logs.
To enable DEBUG:
1. Select Configure Activation, and then select the Tracing Level to be 'DEBUG'.
2. Run the integration and check the activity stream which now will include the runtime log details of the flow.
3. If an activation fails, the Integrations page displays an error.
Some of the sample cases are as follows:
• For any connectivity errors while activating the integration, make sure the trigger connection is working. Test the connection and refresh the metadata, and then activate the integration.
• For Oracle Utilities Work and Asset Cloud Service initiated integration flows activated for the first time, make sure that Oracle Utilities Work and Asset Cloud Service catalog is configured accurately. All external systems and inbound web services used by the integration are defined in the catalog.
