Batch Parameters | Parameter Description | Value |
maintenanceObject | Sync Request maintenance object | F1-SYNC REQ |
isRestrictedByBatchCode | The value of true restrict processing to sync requests whose current state is linked to this batch code. | true |
restrictToBusinessObject | Enter a business object code here to limit the process to sync requests linked to this business object. | X1-NMSDigitalAssetCustSync |
restrictToBOStatus | Enter a status code to limit the process to sync requests in this state. | PENDING |
restrictToBusinessObject | Enter a business object code here to limit the process to sync requests linked to this business object. | X1-GridEdgeDERMSPrgRuleSync |
restrictToBusinessObject | Enter a business object code here to limit the process to sync requests linked to this business object. | X1-GridEdgeDERMSAggregatorSync |
fileName | File Name | drms* Example DERMS filename: drms-model-Site1-20250401161043-1450-438355399355923500.csv |
filePath | File Path to get the file | |
charEncoding | Character Encoding | Default to UTF-8 |
processedFileExtension | Processed File Extension | PROCESSED |
errorOnNoFilesFound | Error When No Files Found | true |
externalSystem | External System DRMS | DRMS |
DIST-THD-POOL | Thread Pool Name | DEFAULT |
maxErrors | Override maximum errors | |
overrideLowIdValue | Override Low Id Value | 00000000000000 |
overrideHighIdValue | Override High Id Value | 99999999999999 |
idRangeOverrideClass | Custom Id Range Class | |
emailMode | Email Mode |
maintenanceObject | Maintenance Object | F1-SYNCREQIN |
restrictToType | Restrict By Related Type | |
restrictToBusinessObject | Enter a business object code here to limit the process to sync requests linked to this business object. | D1-SyncReqInSPNetworkLocation |
restrictToBOStatus | Enter a status code to limit the process to sync requests in this state. | VALID_ERROR |
maintenanceObject | Sync Request maintenance object | W1-ASSET |
isRestrictedByBatchCode | The value of true restrict processing to sync requests whose current state is linked to this batch code. | False |
restrictToBusinessObject | Enter a business object code here to limit the process to sync requests linked to this business object. | X1-Controllable Asset |
restrictToBOStatus | Enter a status code to limit the process to sync requests in this state. | INSTALLED |
isRestrictedByBatchCode | The value of true restrict processing to sync requests whose current state is linked to this batch code. | True |
