Error Handling
This section provides information about the different ways used to handle errors in the integration and also resubmitting the instances after rectifying the errors.
Summary of Integration Error Handling
There are different errors and can be handled in a different way. These are the common types of errors, and all emails are being send via the OU Common Notification Handler integration.
Technical Fault
This fault occurs when there is a data mismatch or any Xpath related error. On this error, the flow immediately goes to global fault handler and the fault is sent back to the respective system.
Remote Fault
This fault occurs when the target system is down. When this error occurs the flow immediately goes to global fault handler and the fault is sent back to the respective system.
Business Fault
This fault occurs only when the business fault occurs in the target system due to invalid data. When this error occurs, the fault is sent back to the respective system as part of immediate response.
Errors in Integration Processes
Integration Process: OU WACS OIC GISMappings Sync
Type of Error
Action
Notification Type
Retry
The attribute size is more than 2k characters.
• Process stops.
• OIC instance is marked as ‘failed’.
Business Error Email (Code 400)
Make sure the size of attributes are less than 2k characters. Or, remove the attributes that are more than 2k characters from the WACS mappings lookup data.
Reschedule the execution in OIC.
Remote fault:
• WACS is down.
• Lookup is not available in OIC.
• Process stops.
Remote Error Email
• Verify that the lookup OUTL-BRT-ArcGIS_WACS_AssetClass is present in OIC.
• Verify that the WACS is down or not.
• Reschedule execution in OIC.
Integration Process: OU ArcGIS WACS Assets Sync
Type of Error
Action
Notification Type
Retry
Incorrect parameters
• Process stops.
Remote fault
• Process stops.
Technical Error Email
• Activate the OU ArcGIS WACS Initial Assets Sync or OU ArcGIS WACS Incremental Assets Sync integrations.
• Reschedule the execution in OIC.
Unexpected Error
• Process stops.
• Review the error email and correct the issue.
Integration Process: OU ArcGIS WACS Initial Assets Sync
Type of Error
Action
Notification Type
Retry
Incorrect Attributes, URL
• Process stops.
Technical Error Email (Code 400)
Attributes in the OIC lookup should not be modified manually.
For invalid URL, verify the connection details and RelativeURI in OUTL-BRT_ArcGIS_WACS_AssetClass.
Remote fault
• Process stops.
• Verify the OIC connection to the ESRI ArcGIS server.
• Activatee the OU WACS Common OS Transfer or OU WACS Common FTP.
Unexpected Error
• Process stops.
Integration Process: OU ArcGIS WACS Incremental Assets Sync
Type of Error
Action
Notification Type
Retry
• Process stops.
Remote fault
• Process stops.
Unexpected Error
• Process stops.
Integration Process: OU WACS Common OS Transfer
Type of Error
Action
Notification Type
Retry
All faults
• Process stops.
• OIC instance returns the fault and is marked as ‘failed’.
N/A
Retry the OU ArcGIS WACS Initial Assets Sync or OU ArcGIS WACS Incremental Assets Sync integration.
Integration Process: OU WACS Common FTP Transfer
Type of Error
Action
Notification Type
Retry
All faults
• Process stops.
N/A
Integration Process: OU Common Notification Handler
Type of Error
Action
Notification Type
Retry
All faults
• Process stops.
N/A
N/A
