Exchange Meter
Meter from the Service Point can be exchanged with a new meter. You can either move all equipment attached to the existing meter to the new meter or attach new equipment to the new meter.
After verifying the new device, the Equipment screen displays the following options:
Attach Equipment
This attach screen is similar to the attach equipment screen that is used to verify the equipment and install the equipment to a new meter.
Transfer Register Equipment
This screen allows you to move register equipment attached to the existing meter to the new meter.
Click
Transfer Register Equipment to move the register equipment of old meter to installed screen.
Note: To undo the Register Equipment move, click Undo Register Equipment Transfer.
Custom Activities Support for Transfer Register Equipment
Currently, the Exchange Meter and Meter Disconnect activities support the Move operation. It does not work for other operations.
To support custom activities:
1. Configure the Custom Activity property.
1. Login to Oracle Field Service.
2. Navigate to Properties and search for "c2m_ert_custom_move_act_types" property.
3. Click
Modify and add the custom activity to the property.
Syntax: [description][Activity type label]
4. In the English field, enter the description and Activity type label.
Example: Move Registers[Move ERT Registers]
5. Click Update. The value is updated in the property list.
2. Add the Condition to the Move Register operation in Inventory Grid.
After adding the custom activity to property, add the custom activity type to the inventory grid condition.
2. Navigate to Configuration > User Type > C2M OFSC.
3. Navigate to
Screen Configuration >
Inventory Grid.
4. Click
Transfer Register Equipment operation and add the condition as below.
5. Select the custom activity type from list of activity types available in the Oracle Field Service environment.
6. Click Save.
7. Add the same condition for the Undo Register Equipment Transfer operation.
