Scheduling Batch Jobs
Run the following Oracle Utilities Digital Asset Cloud Service batch processes:
Enrollment - Sync Request Monitor Process
Sync Request Monitor Process is the batch process to run the sync request to send enrollment out from Oracle Utilities Digital Asset Cloud Service.
• F1-SYNRQ - Sync Request Monitor Process: It is a generic batch process that is used for different synchronization processes. It includes parameters that can be used to control which synchronization request to process.
Batch Parameters
Parameter Description
Value
maintenanceObject
Sync Request maintenance object
F1-SYNC REQ
isRestrictedByBatchCode
The value of true restrict processing to sync requests whose current state is linked to this batch code.
true
restrictToBusinessObject
Enter a business object code here to limit the process to sync requests linked to this business object.
X1-NMSDigitalAssetCustSync
restrictToBOStatus
Enter a status code to limit the process to sync requests in this state.
PENDING
Program Rule - Sync Request Monitor Process
Sync Request Monitor Process is the batch process to run the sync request to send program rule out from Oracle Utilities Digital Asset Cloud Service.
• F1-SYNRQ - Sync Request Monitor Process: It is a generic batch process used for different synchronization processes. It includes parameters that can be used to control which synchronization request to process.
Batch Parameters
Value
maintenanceObject
F1-SYNC REQ
true
X1-GridEdgeDERMSPrgRuleSync
restrictToBOStatus
PENDING
Aggregator - Sync Request Monitor Process
Sync Request Monitor Process is the batch process to run the sync request to send aggregator out from Oracle Utilities Digital Asset Cloud Service.
Batch Parameters
Value
maintenanceObject
F1-SYNC REQ
true
X1-GridEdgeDERMSAggregatorSync
restrictToBOStatus
PENDING
SP Network Location Batch Processes
These batch processes need to be run to upload the file, create or update the facilities for the transformer, feeder and substation and create or update the network location and link it to the SP.
Schedule the following batch jobs in the order they are listed below:
• D1-NLUP - Network Location File Upload: This batch process uploads and creates a synchronization request for each record in the file to Oracle Utilities Digital Asset Cloud Service.
Batch Parameters
Value
fileName
File Name
drms*
Example DERMS filename:
drms-model-Site1-20250401161043-1450-438355399355923500.csv
filePath
File Path to get the file
charEncoding
Character Encoding
Default to UTF-8
processedFileExtension
Processed File Extension
PROCESSED
errorOnNoFilesFound
Error When No Files Found
true
externalSystem
External System DRMS
DRMS
• D1-MNLOC – Maintain Network Location: This batch process maintains the network location and creates the facility if the transformer, feeder or substation does not exist in Oracle Utilities Digital Asset Cloud Service.
Batch Parameters
Value
DIST-THD-POOL
Thread Pool Name
DEFAULT
maxErrors
Override maximum errors
overrideLowIdValue
Override Low Id Value
00000000000000
overrideHighIdValue
Override High Id Value
99999999999999
idRangeOverrideClass
Custom Id Range Class
emailMode
Email Mode
• D1-SNLPE – SP NW Loc Sync Request – Pending (deferred): This batch process create or update the Network Location and link it to the SP.
Batch Parameters
Value
maintenanceObject
Maintenance Object
F1-SYNCREQIN
true
restrictToType
Restrict By Related Type
D1-SyncReqInSPNetworkLocation
restrictToBOStatus
PENDING
Batch Parameters
Value
maintenanceObject
Maintenance Object
F1-SYNCREQIN
true
restrictToType
restrictToBOStatus
VALID_ERROR
Device Score Batch Processes
These batch processes calculate and send out the device score to Oracle Utilities Edge Distributed Energy Resources Management System. Schedule the following batch jobs in the order they are listed below:
• X1-CALAS - Calculate Asset Score: This batch process monitors controllable assets that are currently installed on a device location and enrolled in a device control program. It triggers the calculation of device’s score based on its previous program event participation, as well as other factors set on a program score calculation rule.
Batch Parameters
Value
maintenanceObject
W1-ASSET
False
X1-Controllable Asset
restrictToBOStatus
INSTALLED
• X1-SDCSE - Smart Device Control Score Extract: This batch process creates the device score extract file.
Batch Parameters
Value
maintenanceObject
F1-SYNC REQ
True
restrictToBOStatus
PENDING
