Solution Overview
The technical aspects involved in the integration between Oracle Utilities Digital Asset Cloud Service and Oracle Utilities Edge Distributed Energy Resources Management System are:
• The integration layer consists of integration processes deployed on Oracle Integration Cloud.
• The integration processes interact with other applications using the following adapters:
• Oracle Utilities Adapter interacts with the DACS REST APIs and Edge DERMS REST APIs.
• REST Adapter interacts with Oracle Cloud Infrastructure Object Storage REST APIs.
• FTP Adapter interacts with Oracle Utilities Digital Asset Cloud Service On Premise Server to list, get, and rename files in the server.
• Two types of email notifications can be configured in this integration:
• Business email notifications:
These notifications are used in file processing flows.
In the OUTL-BRT-DACS_DRMS_ConfigProps lookup, configure the following properties to enable or disable notifications:
• Set property name notification.email.process.complete.flag to ‘true’ to receive an email notification when the process is completed or partially processed. By default, this is set to ‘true’.
• Set property name notification.email.process.nofile.flag to ‘true’ to receive an email notification when no file is found in the source location. By default, this is set to 'true'.
The recipient(s) of these email notification are configured in the to.process.notification recipients of lookup OUTL-BRT-DACS_DRMS_Email_ID. These are sent to the application business users.
• Technical error email notifications:
These notifications are sent when a technical fault is encountered. Some examples are authentication error, connection issues or server unavailable.
In the OUTL-BRT-DACS_DRMS_ConfigProps lookup, configure the property name notification.email.error.flag to ‘true’ to receive email notification when errors are encountered. By default, this is set to ‘true’.
The recipient(s) of the error email notification are configured in the to recipients of lookup OUTL-BRT-DACS_DRMS_Email_ID. These are sent to the application administrator(s).
Note: Email notifications are optional but are enabled by default.
• Lookup OUTL-BRT-DACS_DRMS_ConfigProps is used to define the default values needed by the integration flows. Make sure the properties in the lookup are configured.
• Integration related DVM lookups are used for translation of values from one application to the other. Make sure these DVM lookups are configured.
• In the Oracle Utilities Digital Asset Cloud Service initiated processes, batch processes are used to send the outbound messages or to create file(s) and upload to the content server defined for an external application to pull for processing. For inbound messages, it uses REST inbound web services (IWS) to receive messages and batch processes for file upload.
• In the Oracle Utilities Edge Distributed Energy Resources Management System initiated processes, events are triggered to send the outbound messages and files, if applicable. For inbound messages, it uses REST APIs to receive the messages and files, if applicable.
• For Scheduled Integration processes related to file transfer, make sure the dependent application extract processes are ran first so the files are already available in the content server for the integration process to pick up.
• The integration uses One-way Asynchronous pattern.
The one-way asynchronous integration process:
1. Receives request message from the source application.
2. Transforms message from the source to the target format. Lookups are used for data translations, if applicable.
3. Invokes target application to send the request message.
4. In case of any error, the global fault handler catches the error.
5. An optional email notification is sent to the respective users as configured.
6. The error instance can be re-submitted from Oracle Integration Cloud. Refer to the Error Handling section in Configuring Lookups, Error Handling, and Email Notifications for more details. Shows the one-way asynchronous integration process.
