Scenario 1: CC&B – MWM - WAM v1.9.1.x
In this scenario, the integration product coordinates processing between three Oracle Utilities application products based on the configuration settings described. All two or three application products and the integration product must be configured to enable this business scenario. This section of the document describes the configuration required for one of the application products.
To configure the integration layer for Scenario 1:
Setting AIA Configuration Properties
Various configurations that apply to the entire Oracle AIA system, Core Infrastructure Components, and specific process integration services are stored in the AIAConfigurationProperties.xml file which is stored in MDS.
This section lists the configurations in this file that are used by the integration layer. These configurations hold several configurable values that are picked up by the integration at runtime to:
• Default some business entity value sent to the target edge applications when the data is moved from one system to another. These configuration values may need to be updated to your implementation specific values for the integration to work correctly. These properties are described in this section in detail.
• Activate custom implemented extension points available inside the ABCS. By default these properties are set not to invoke any of the extension points as the extension points need to be implemented using the AIA ABCS Extension guidelines before being activated. These properties need to be changed only if you decide to extend the core functionality provided by this Process integration Pack, using the predefined ABCS extension points. These properties are not listed in this section but can be identified in the AIAConfigurationProperties.xml file as the name of these Service Configuration properties start with ABCSExtension and are available in the file under each ABCS Name.
For more information on extending the ABCS using extension points, refer to Chapter 19: General Extensibility Options.
• Get the endpoint URLs for Provider ABCS. These properties are set to appropriate values during the installation of Process Integration Pack, based on the information specified during the installation. You should not have to modify the values.
Settings for System Properties
Two sets of configuration properties are described in this section:
• Module Configurations are the properties that are shared by multiple integration processes within the integration layer.
• Service Configurations are the properties that are used by a specific ABCS.
Module Name
Property Name
Default / Shipped Value
Integration Point
Description
OUFieldWorkPIP
WorkOrderAction
Codes
WorkOrder.ActionCode.
CREATE
CREATE
Work Order
This is internally used by the integration to identify the messages sent for Work order creation. Do not change the value of this property.
OUFieldWorkPIP
WorkOrderAction
Codes
UPDATE
UPDATE
Work Order
This is internally used by the integration to identify the messages sent for Work order updates. Do not change the value of this property.
OUFieldWorkPIP
WorkOrderAction
Codes
COMPLETE
COMPLETE
Work Order
This is internally used by the integration to identify the messages sent for Work order completion. Do not change the value of this property.
OUFieldWorkPIP
WorkOrderAction
Codes
CANCEL
CANCEL
Work Order
This is internally used by the integration to identify the messages sent for Work order cancellation. Do not change the value of this property.
OUFieldWorkPIPWorkOrderActionCodes
INCOMPLETE
IN-COMPLETE
Work Order
This is internally used by the integration to identify the messages sent for Work order incomplete transactions. Do not change the value of this property.
STATUSUPDATE
STATUSUPDATE
Work Order
This is internally used by the integration to identify the messages sent for Work order status updates. Do not change the value of this property.
OUWAM
WAM.WorkOrder.Default.MessageID
0000000000
Work Order
This is a default message ID used for Work Order messages sent from WAM. Do not change the value of this property.
OUWAM
WAM.Default.PLANT
FWI
Work Order
This specifies the WAM plant that it is integrated with.
OUMWM
OUMWM.Transaction
Code.CREATE
M2UP
Work Order
The MWM transaction code set on the Work Order Create messages inbound to MWM. Do not change.
OUMWM
OUMWM.Transaction
Code.UPDATE
M2UP
Work Order
The MWM transaction code set on the Work Order Update messages inbound to MWM. Do not change.
OUMWM
OUMWM.Transaction
Code.CANCEL
M2CA
Work Order
The MWM transaction code set on the Work Order Cancel messages inbound to MWM. Do not change.
OUMWM
OUMWM.Transaction
Code.COMPLETE
M2CO
Work Order
OUMWM
OUMWM.timeUsage
Window
M1EF
Work Order
This specifies the timeUsageWindow in MWM. Do not change.
OUMWM
OUMWM.Plant
FWI
ALL IPs
This specifies the WAM plant that MWW is integrated with.
OUMWM
OUMWM.External
System
FWI-PIP
ALL IPs
This is the external system configured in the MWM.
OUWAM
OUWAM.Transaction
Code.CREATE
W1AD
WorkOrder
The WAM Transaction code set on the Work Order Create messages inbound/outbound for WAM v2.1.x. Do not change.
OUWAM
OUWAM.Transaction
Code.UPDATE
W1UP
WorkOrder
The WAM transaction code set on the Work Order Update messages coming from WAM v2.1.x. Do not change the value of this property for WAM v2.1.x.
OUWAM
OUWAM.Transaction
Code.CANCEL
W1CA
WorkOrder
The WAM Transaction code set on the Work Order Cancel messages coming from/to WAM v2.1.x. Do not change the value of this property for WAM v2.1.x.
OUWAM
OUWAM.IdentifierType.
PIPActivity
W1FA
WorkOrder
The Identifier Type is used by WAM v2.1.x to determine the types of identifiers being passed in. This identifier type is used to identify the PIP Id. Do not change the value of this property for WAM v2.1.x.
OUWAM
OUWAM.IdentifierType.CCBActivity
W1CF
WorkOrder
The Identifier Type is used by WAM v2.1.x to determine the types of identifiers being passed in. This identifier type is used to identify the CCB Id. Do not change the value of this property for WAM v2.1.x.
OUWAM
MWMActivity
W1MT
WorkOrder
The Identifier Type is used by WAM v2.1.x to determine the types of identifiers being passed in. This identifier type is used to identify the MWM Activity ID. Do not change the value of this property for WAM v2.1.x.
OUWAM
OUWAM.ExternalSystem
MWM
WorkOrder
This identifier is used by WAM 2.1.x to determine the types of identifiers passed in to identify the MWM external system. Do not change the value of this property for WAMv2.1.x.
OUWAM
OUWAM.IdentifierType.CCBSP
W2EI
WorkOrder
This identifier is used by WAM 2.1.x to determine the types of identifiers passed in to identify the Servicepoint information. Do not change the value of this property for WAMv2.1.x.
OUWAM
OUWAM.CCB.ExternalSystem
CCB
WorkOrder
This identifier is used by WAM 2.1.x to determine the types of identifiers passed in to identify the CCB external system. Do not change the value of this property for WAMv2.1.x.
OUWAM
RelatedActivity
W1RA
WorkOrder
The Identifier Type is used by WAM v2.1.x to determine the types of identifiers being passed in. This identifier type is used to identify the parent WAM Activity ID. Do not change the value of this property for WAM v2.1.x.
ABCS Configurations
ABCS Name
Property Name
Description
CreateCustomerInteractionOUWAMUtilitiesReqABCSImpl
ContactClass
SVC
Used by the customer interaction process to specify an CC&B Contact Class to be used when a customer contact is created in CC&B by this process.
Specify the contact class created above for this property.
Refer to Customer Contact Class and Type for configuration details.
ContactType
MISC
Used by the customer interaction process to specify an CC&B Contact Type to be used when a customer contact is created in CC&B by this process.
Specify the contact type created above for this property.
Description
Added with WAM Requester ABCS to create Customer Contact in CC&B
This is the Description that is specified on the Customer Contact when it is created in CC&B by the customer interaction. You can change this to the text that you wish to have on these customer contacts.
ToDoRole
SUPPORT
Used by the customer interaction process to specify a CC&B ToDORole to be used when a ToDo is created in CC&B by this process.
Set this property to the created/identified To Do Role for this purpose.
Refer to To Do Type/ To Do Role for configuration details.
TriggerDay
20
This property is for future use. Do not modify.
TriggerToDo
YES
CreateInvoiceOUCCBUtilitiesProvABCSImpl
CCB.BillableChargeSATypeCode
MI-SUBCH
This is the CC&B SA Type used by Billable Charge Integration process for finding or creating a Billable Charge SA. Set this to the appropriate CC&B SA Type that you use for this purpose.
CCB.CisDivisionCode
OH
This is the default CIS Division to use for finding or creating a Billable Charge SA in CC&B. This is only used when CC&B cannot find the CIS Division for the input Account or SP. Set this to the appropriate CC&B CIS Division that you use for this purpose.
CCB.OrderIDCharacteristicTypeCode
CI_SOLID
This is the Characteristic Type to use for storing the common Work Order ID in the Billable Charge Upload Line Characteristics.
CCB.SAStartOption
<blank>
This is the SA Start Option used for finding or creating a Billable Charge SA. This is an optional field. You can specify a valid CC&B SA Start Option to be used for this purpose.
CCB.ToDoMessage
Category
90000
Set this to a valid CC&B Message Category that you want to be used for To Do entries created by the Billable Charge process.
Set this property to the created/identified To Do Message Category for this purpose.
CCB.ToDOMessage
Number
5010
Set this to a valid CC&B Message Number that you want to be used for To Do entries created by the Billable Charge process.
Set this property to the created/identified To Do Message Number for this purpose.
CCB.ToDoRole
<blank>
CC&B To Do Role to be used by Billable Charge process, for the creation of a To Do Entry when multiple accounts are linked to an SP. This is an optional field.
Set this property to the created/identified To Do Role for this purpose if needed.
CreateInvoiceOUCCB
CCB.ToDOTypeCode
CI_WRNMU
CC&B To Do Type to use by Billable Charge process, for the creation of a To Do Entry when multiple accounts are linked to an SP.
Set this property to the created/identified To Do Type for this purpose.
CreateInvoiceOUCCB
Utilit iesProvABCSImpl
CCB.BillableChargeDescriptionOnBill
Field Work Charges
This property is used to default the Billable Charge Description on Bill.
GetWOLineApptWinAvailOUCCBUtilitiesReqABCSImpl
CCB.ResponseCodeFor
ErrorAppointment
100
This is the response code used by Appointments when there is an error retrieving the appointment slots. For internal use only. Do not modify.
CCB.ResponseCodeForSuccessWithoutAvailable
Appointment
101
This is the response code used by Appointments when no appointment slots were found for the search criteria specified. For internal use only. Do not modify.
GeoCodeLatitude
GeoCodeLongitude
LAT
LONG
Specify the value for the CC&B Geo Types used on service point to indicate geographic coordinates.
Refer to Geographic Type for configuration details.
GetWOLineApptWinAvailOUMWMUtilitiesProvABCSImpl
24hours.Default.Value
2400
This value is for internal use by this integration. Do not modify.
destination.Default.Value
RTS
This value is for scheduler system use for routing appointment request to end MWM application. This value is for internal use. Do not modify.
ABCSImpl
FONumber.Default.Value
00000
This is the default Field Order Number used by the Appointments when the order number is missing in the Request for appointment slots sent from CC&B. For internal use only. Do not modify.
ABCSImplV2
MaxApptWinCount.
Default.Value
1000
Default value of Max Appointment Window Count
ABCSImplV2
MaxCostUnits.Default.
Value
1e99
Default value of Max Cost Units.
GetWOLineApptWinAvail OUMWMUtilitiesProv
ABC SImplV2
SlotGroup.Default.
Value
<blank>
Default value of SlotGroup.
It is empty by default.
ProcessWorkOrderCompleteOUMWMUtilitiesReq
ABCSImplV2
Default.Cancel.Reason
Canceled/
Completed in WAM
This is the cancellation reason text sent to WAM when MWM cancels a Work Order. You can change this to the text that you wish to use for this purpose.
ABCSImplV2
Default.Plant
FWI
This is the default Plant Information sent from MWM to WAM
ProcessWorkOrderComplet eOUMWMUtilitiesReq
ABC SImplV2
Default.MeterReadSource
FWI
This is the default meter read source.
ABCSImpl
MWM.Pass.Representative.
Information
true
This is used to indicate whether or not the representative ID is to be passed to CC&B.
If the property is false indicating that the representative ID should not be passed to CC&B, then the CC&B Provider uses the generic representative configured in the AIA Configuration.
If the property is true indicating that the representative ID should be passed, the MWM requester passes the representative ID to the Integration layer. The integration layer looks up the new DVM and passes the value configured in the DVM.
If the Crew Data is synchronized between CC&B and MWM, this DVM can be left empty. When DVM is left empty, integration layer passes the CrewID coming from MWM directly to CC&B without any transformation.
ABCSImplV2
Information
false
ProcessWorkOrder
CompleteOUWAM
WAM.Pass.Representative.
Information
true
This is the WAM Pass Representative Information.
ProcessWorkOrderCreateO UMWMUtilitiesReq
ABCSI mplV2
MWM.SPValidation.MessageCategory
11503
Message Category populated for SP Validation
ABCSI mplV2
MWM.SPValidation.MessageNumber
11214
Message Number populated for SP Validation
ProcessWorkOrderOUCCBUtilitiesReqABCSImpl
OUCCB.PhoneType.Value
HOME
Default Phone Type value passed from C&CB
OUMWMUtilitiesReq
ABCSImplV2
CreateCustomerContact.
Flag
false
Set to either True or False to indicate whether a customer contact is to be created in CC&B along with field activities that are created by the integration. This property is used by Work Order process, when an Order Create request is sent from MWM to CC&B.
OUCCB.GeoCode
Latitude
OUCCB.GeoCode
Longitude
GRID_X
GRID_Y
OUWAMUtilitiesReq
ABCSImpl
Default.Dispatch.Group
FWIUSER
This is the dispatch group used by Work Order process for all Order Creates sent from WAM to CC&B. Set this value to match with one of the values in the DVM FS_Order_DispatchGroup under column OU_WAM_01.
OUWAMUtilitiesReq
ABCSImpl
Default.Enrichment.For.
Meter.SystemID
OU_CCB_01
This is used by the Work Order process to identify the application used for retrieving meter and register information for Order Create messages sent from WAM. Do not modify.
ProcessWorkOrderOUCCBUtilitiesProvABCSImpl
CCB.CustomerContact.
Class
CC
This is the CC&B Customer Contact Class that is used by Work Order process when this process creates a new field activity in CC&B as a result of Order Create Request from WAM or MWM.
Set this property to the created/identified Customer Contact Class for this purpose.
Desc
New SR created from Field Work Integration.
This is the Description that is specified on the Customer Contact when it is created in CC&B by the Work Order process when this process creates a new field activity in CC&B as a result of Order Create Request from WAM or MWM. You can change this to the text that you wish to have on customer contacts.
Type
INQUIRE
This is the CC&B Customer Contact Type that is used by Work Order process when this process creates a new field activity in CC&B as a result of Order Create Request from WAM or MWM.
Set this property to the created/identified Customer Contact Type for this purpose.
CCB.Representative.
FACompletion
MWMCR1
The representative to be used when MWM or WAM sends an order completion message to CC&B. Must be valid in CC&B for the CC&B Dispatch Group(s) used for sending orders.
CCB.ToDoRole
CIACTIV
Specify the value for the CC&B user role that the To DoEntry created by the Work Order process should be assigned to.
ProcessWorkOrder
OUWAMUtilitiesProv
ABCSImpl
Default.Employee.For.
InventoryLog
MWM, INTEGRATION
This is the default WAM checkout employee used by the Work Order process for the inventory log transactions sent from MWM to WAM with the Order Completion message. All the inventory log transactions are created for this WAM employee. Set this to a valid WAM employee name to be used for this purpose. The name is to be specified in the format <Employee Last Name>, <Space><Employee First Name>.
ProcessWorkOrderResponseOUCCBUtilitiesProvABCSImpl
Default.Create.FA.Log
true
Values are true and false. This is used by Work Order Integration process while sending positive or negative acknowledgments back into CC&B and determines if a FA Log entry is to be created in CC&B on the receipt of the acknowledgment.
Default.Notification.
External.ID
AIA-FS
This is the CC&B Notification External ID used by the Work Order integration process while sending positive or negative acknowledgments back into CC&B for Order messages sent out by CC&B. Set this to a valid External System. Refer to Setting Up CC&B > Configure Notification Download Staging section for more information.
Default.Reply.To.
Message.Source
AIA-FS
This is the CC&B Reply To Message Source used by the Work Order integration process while sending positive or negative acknowledgments back into CC&B for Order messages sent out by CC&B. Set this to a valid External System. Refer to Setting Up CC&B > Configure Notification Download Staging section for more information.
ProcessWorkOrderUpdateOUWAMUtilitiesReqABCSImpl
Default.Dispatch.
Group
FWIUSER
This is the dispatch group used by Work Order flow for all Order Creates sent from WAM to CC&B. This value must match the value of the Default.Dispatch.Group, which was set for Create messages in a previous step.
IntermediateStatus
CREX
This is used to identify the intermediate status code sent by WAM for Work Order Update messages. Do not modify.
ProcessWorkOrder
CompleteOUWAMUtilities
ReqABCSImpl
Information
true
If the property is true indicating that the representative ID should be passed, the WAM requester passes the representative ID to the Integration layer. The integration layer looks up the new DVM and passes the value configured in the DVM.
If the Crew Data is synchronized between CC&B and WAM, this DVM can be left empty. When DVM is left empty, integration layer passes the CrewID coming from WAM directly to CC&B without any transformation.
ProcessWorkOrder
ReqABC SImpl
Canceled in WAM
This is the cancellation reason text sent to CC&B/MWM with the cancellation request, when WAM cancels a Work Order. You can change this to the text that you wish to use for this purpose.
ValidateInstalledProduct
OUMWMUtilitiesReq
ABCSImplV2
Transaction.Code
Read
Default value of Transaction Code. Do not change this property value
Domain Value Maps
Domain value maps (DVMs) are a standard feature of the Oracle SOA Suite which maps codes and other static values across applications. The DVMs are stored in MDS. For example, For example, country code in one application can be US in one application and USA in another application.
DVMs are static in nature, though administrators can add additional maps as needed. Transactional business processes never update DVMs—they only read from them. They are stored in XML files and cached in memory at runtime.
Maintain the Information within Domain Value Maps
1. Open a browser and access the SOA Composer (http://soa-server:soa-port/soa/composer) for your installation.
2. On the SOA Composer application open DVM.
3. Search and select the relevant DVM you wish to maintain.
4. Set up the required values for each integrated application.
The Oracle Process Integration Pack for Oracle Utilities Field Work work includes the following DVMs:
DVM
Integration Points
Description
FS_Invoice_ChargeLineTypeCode
BillableCharge
DVM mapping for charge line type code
FS_Order_DisconnnectLocationCode
WorkOrder
DVM mapping for disconnect location code
WorkOrder, AvailableAppointment
DVM mapping for dispatch group
FS_Order_Division
DVM mapping for division
FS_Order_ExpenseTypeCode
WorkOrder
DVM mapping for expense type code.
FS_Order_ItemStatusCode
WorkOrder
DVM mapping for item status code
FS_Order_ItemStockLocationCode
WorkOrder
DVM mapping for item stock location code
FS_Order_ItemTypeCode
WorkOrder
DVM mapping for item type code
FS_Order_MeterConfigurationType
WorkOrder, InstalledProduct
DVM mapping for meter configuration type
FS_Order_MeterStatusCode
WorkOrder
DVM mapping for meter status code
FS_Order_MeterStockLocationCode
WorkOrder
DVM mapping for meter stock location code
FS_Order_MeterTypeCode
WorkOrder
DVM mapping for meter type code
FS_Order_OperationsArea
DVM mapping for operations area.
For WAM, this is set up as Dept**Area
FS_Order_ReadTypeCode
WorkOrder
DVM mapping for meter read type code
FS_Order_RegisterReadUnitCode
DVM mapping for register read unit code
FS_Order_RegisterTimeOfUseCode
DVM mapping for register read time of use code
FS_Order_ServicePointTypeCode
DVM mapping for service point type code
FS_Order_Status
WorkOrder
DVM mapping for order status
FS_Order_SubStatus
WorkOrder
DVM mapping for order sub status
FS_Order_TypeCode
DVM mapping for order type code.
For WAM, this is set up as Service Request Type**Problem Code
FS_Order_Worker
WorkOrder
DVM mapping for Representative ID values
FS_Order_RemarksCode
WorkOrder
DVM mapping for Remarks Code values
FS_Order_StepType
WorkOrder
DVM mapping for Step Type values
FS_Order _SlotGroup
DVM mapping for Slot group for an Appointment values
FS_Order_MeterLocationCode
WorkOrder
DVM mapping for Meter Location Code values
FS_Order_PriorityCode
WorkOrder
DVM mapping for Priority Code values
FS_Order_TimeZone
WorkOrder
DVM mapping for passing Time Zone Code values
FS_Country_Code
WorkOrder
DVM mapping to pass Country Codes
FS_Language_Code
InstalledProduct
DVM mapping to pass Language Codes
FS_Order_TypeCode_Use
ReadingOnBill
WorkOrder
DVM mapping to map UseOnBill Indicator based on Order Type Code
FS_Order_ManufacturerCode
WorkOrder
DVM mapping to map Manufacturer code of Meter/Item.
FS_Order_ServiceWarnings
WorkOrder
DVM mapping to map service warnings
FS_Order_ServiceInstructions
WorkOrder
DVM mapping to map service instructions
FS_Order_PremiseTypeCode
WorkOrder
DVM mapping to map Premise Type
FS_Order_ServiceTypeCode
WorkOrder
DVM mapping to map Service Type
FS_BO
ServicePoint
DVM mapping to business object
FS_MO
ServicePoint
DVM mapping to maintenance object
FS_ErrorCodes
ServicePoint
DVM mapping to error information
FS_SPNodeType
ServicePoint
DVM mapping to SP Type information
FS_NodeDisposition
ServicePoint
DVM mapping to disposition information
FS_Order_RegisterSeqCode
WorkOrder
DVM mapping to register sequence information
FS_LifeSupportSensitiveLoad
ServicePoint
DVM mapping to Lifesupport Sensitive information
FS_OkToEnterCode
ServicePoint
DVM mapping to pass true or false
For more information about DVMs, refer to the Working with Domain Value Maps section in the Oracle Fusion Middleware Developing SOA Applications with Oracle SOA Suite.
Bill charge line types simplify the creation of billable charges in Oracle Utilities Customer Care and Billing. Each line type contains values that are defaulted onto the line details associated with the uploaded billable charges.
When billing information is sent from Oracle Utilities Work and Asset Management v1.9.1.x to Oracle Utilities Customer Care and Billing, using the Invoice integration point, this DVM is used to populate the appropriate value for the bill charge line type. This bill charge line type is then used within Oracle Utilities Customer Care and Billing to control the behavior of the billable charge.
Common
OU_CCB_01
OU_WAM_01
OU_CCB_SHOW_ON_
BILL
AIA common value: Describes the type of charge line. Must be unique for each DVM row.
Must match values for Bill Charge Line Type.
Must match values for Category in the EXPENSE CODE Business Rule.
This information is used to populate the Description on Bill information for the Billable Charge Upload Staging Line.
This is the description of the charge line that appears on the customer’s bill in CC&B.
Note that since MWM is not involved in the Invoice integration point that uses this DVM, the OU_MWM_01 column is not used and should be left blank.
When a service point is disconnected from the supply source, a disconnect location must be specified. This location defines where service was severed.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the disconnect location. Must be unique for each DVM row.
Must match values for Disconnect Location
Must match values for Disconnect Location in Code Table 246.
Must match values for Disconnect Location Code.
MWM uses the Disconnect Location Extendable Lookup
A dispatch group is a logical group of representatives located at an operations area. When a field activity is created, the system assigns it to a dispatch group based on the type of activity, the type of service point, and the operations area that manages the service point.
Each of the edge applications in use may refer to a dispatch group differently. To account for these differences, create the mapping between the dispatch groups in each application using this DVM.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the dispatch group. Must be unique for each DVM row.
Must match values for Dispatch Group
WAM does not store a Dispatch Group. This column can be blank except for one row where the value is set to the default WAM Dispatch Group as specified in the AIA Configuration Properties. The property is Default.Dispatch.Group for WAM create and update requester.
Must match values for Service Area.
Maps Item Status code from Oracle Utilities Mobile Workforce Management to Oracle Utilities Customer Care and Billing when Oracle Utilities Mobile Workforce Management sends Order Completion to Oracle Utilities Customer Care and Billing with Item information.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the Status. Must be unique for each DVM row.
Must match with valid On-Off Status in CC&B related to Items. The values in CC&B are 0 for OFF and 1 for ON.
Leave blank.
MWM uses the M2_DEVICE_STATUS_FLG Lookup.
A stock location is a physical or logical location at which items are stored while they are not installed at a service point. When an item is removed from a service point the stock location must be entered. Each edge application involve may have different codes for the various stock locations.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the item stock location. Must be unique for each DVM row.
Must match values for ‘Stock Location’.
Leave blank.
MWM uses the Stock Location Extendable Lookup
Items are any type of equipment, other than meters. Every item has an item type that defines characteristics common to all items with this type. Each edge application involve may have different codes for the item types.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the item type. Must be unique for each DVM row.
Must match values for Item Type.
Leave blank.
Leave blank.
Every meter configuration must reference a meter configuration type. Each edge application involve may have different codes for the meter configuration types.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the meter configuration type. Must be unique for each DVM row.
Must match values for Meter Configuration Type.
Must match the CC&B value on the corresponding rows.
MWM uses the Meter Configuration Type Extendable Lookup
Maps the Meter Status code between Oracle Utilities Mobile Workforce Management, Oracle Utilities Work and Asset Management v1.9.1.x and Oracle Utilities Customer Care and Billing when Oracle Utilities Mobile Workforce Management or Oracle Utilities Work and Asset Management v1.9.1.x sends Order Completion to Oracle Utilities Customer Care and Billing with Meter information.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
Must match valid Meter On-Off Status in CC&B. The values in CC&B are 0 for OFF and 1 for ON.
Must match valid Meter Status in WAM. The values in WAM are 0 for OFF and 1 for ON.
A stock location is a physical or logical location at which meters are stored while they are not installed at a service point. When a meter is removed from a service point its stock location must be input. Each edge application involve may have different codes for the various stock locations.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the meter stock location. Must be unique for each DVM row.
Must match values for Stock Location
Must match the MWM value on the corresponding rows.
Every meter references a meter type. The meter type defines the type of service and common characteristics shared by its meters. Each edge application involved may have different codes for the various meter types.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the meter type. Must be unique for each DVM row.
Must match values for Meter Type
When a service point is set up, the operation areas that manage its fieldwork are defined. Each edge application involved may have different codes for the various operation areas. v1.9.1.x.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
OU_WAM_05
AIA common value: Describes the operation area. Must be unique for each DVM row.
Must match values for Operation Area
Set to a combination of valid WAM department code and area code. Use the format: <department_code>**<area_code>.
Must match values in the MWM configuration table
DHTDIST, column DISTRICT.
Specify a valid WAM account code to be used as the default account for each combination of WAM department and area, to be used on the SR.
Read type indicates who read a meter and how it was read. This information accompanies meter register reading data. Each edge application involved may have different codes for read types.
This DVM is shipped with required values populated. You should not need to change these values.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the read type code. Must be unique for each DVM row.
CC&B values for this column are 60 and 70.
Register read unit code indicates the units of measure of the register reading. This information accompanies meter register reading data. Each edge application involved may have different codes for units of measure.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the register read unit code. Must be unique for each DVM row.
Specify a list of Unit of measure valid in CC&B.
MWM uses the Unit Of Measure Extendable Lookup
Maps register time of use (TOU) codes between Oracle Utilities Customer Care and Billing, Oracle Utilities Work and Asset Management v1.9.1.x and Oracle Utilities Mobile Workforce Management.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the register TOU. Must be unique for each DVM row.
Specify a list Time Of Use Codes valid in CC&B.
MWM uses the Time Of Use Extendable Lookup
Every service point must reference a service point (SP) type. The SP type controls almost all aspects of the service point behavior (for example, the type of field activity that may be dispatched to it, the type of service agreement that may be linked to it, the type of meter that may be installed at it). Each edge application involved may have different codes for SP Type.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the service point type. Must be unique for each DVM row.
Specify a list of Service Point Types valid in CC&B.
Must match values for Asset Type Codes Code Table. The Asset Type codes in this code table that correspond to the CC&B Service Point type codes need to be listed in this DVM.
n/a
FS_Order_Status
Order status indicates the current state or status of the order such as Active, Held, or Finished. Each edge application involved may have different codes for Status.
This DVM is shipped with required values predefined. You should not need to change these values.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
OU_WAM_01_CANCELED
AIA common value: Describes the order status. Must be unique for each DVM row.
A list of valid CC&B FA Statuses has been specified in this column.
A list of valid WAM SR Statuses has been specified in this column.
A list of valid MWM FO Statuses has been specified in this column.
A list of valid WAM statuses for canceled messages in WAM.
FS_Order_SubStatus
For status updates from Oracle Utilities Work and Asset Management v1.9.1.x to Oracle Utilities Customer Care and Billing, this maps Oracle Utilities Work and Asset Management v1.9.1.x status codes to Oracle Utilities Customer Care and Billing Intermediate Status Codes. For status updates from Oracle Utilities Mobile Workforce Management to Oracle Utilities Customer Care and Billing, this maps Oracle Utilities Mobile Workforce Management Transaction codes to Oracle Utilities Customer Care and Billing Intermediate Statuses.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the intermediate status. Must be unique for each DVM row.
Specify a list of valid CC&B intermediate statuses.
Must match values for WAM service request status and must contain a row with the value CREX in this column with the corresponding CC&B value also specified as CREX.
Specify MWM transaction IDs corresponding to the intermediate status in CC&B. A list of values is shipped for this DVM.
FS_Order_TypeCode
The order type code is used for two important functions:
• Mapping field activity type values, Service Request Type and Problem Code values, and Field Order Type values between the edge applications involved in the integration.
• Determining which applications an order is routed to when it is created.
Column
Description
COMMON
AIA common value: Describes the order type. Must be unique for each DVM row.
OU_CCB_01
Must match values for field activity types
OU_WAM_01
This holds a concatenation of two values:
Service Request Type (WAM Code table 240)
Problem Code (WAM Code table 241)
These are separated by “**” for example in the format: <WAM SR Type>**<WAM Problem Code>.
OU_MWM_01
Must match values for activity types in MWM.
ROUTE_TO_CCB
When this value is set to Y orders of this type are routed to CC&B when they are created by either WAM or MWM. When set to N orders are not routed.
ROUTE_TO_WAM
When this value is set to Y orders of this type are routed to WAM when they are created by either CC&B or MWM.
ROUTE_TO_MWM
When this value is set to Y orders of this type are routed to MWM when they are created by either WAM or CC&B. When set to N orders are not routed.
FS_Order_Worker
This indicates the Representative ID of the person who worked on the Order. This information is used for identifying the exact Crew who worked on any particular Order. This is an optional setup and required only if the crews are not synchronized between the edge applications.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the representative ID. Must be unique for each DVM row.
CC&B Representative ID value
Must match Crew ID
Must match WorkedBy Field
This indicates the Remarks Codes associated with an Order. Remarks codes are mapped from Oracle Utilities Mobile Workforce Management and/or Oracle Utilities Work and Asset Management v1.9.1.x into Oracle Utilities Customer Care and Billing.
Oracle Utilities Mobile Workforce Management and Oracle Utilities Work and Asset Management v1.9.1.x send a list of codes to Oracle Utilities Customer Care and Billing.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the remarks code. Must be unique for each DVM row.
CC&B Remarks Code value
WAM Remarks code value
MWM Remarks Code value
FS_Order_StepType
This indicates the Step Types associated with an Order sent from Oracle Utilities Customer Care and Billing. Step Types are mapped between Oracle Utilities Customer Care and Billing, Oracle Utilities Mobile Workforce Management and Oracle Utilities Work and Asset Management v1.9.1.x.
This DVM only maps Oracle Utilities Customer Care and Billing Step type to Common Step type. Oracle Utilities Mobile Workforce Management or Oracle Utilities Work and Asset Management v1.9.1.x step types are not mapped. The implementation can customize and use this DVM to map to Oracle Utilities Work and Asset Management v1.9.1.x or Oracle Utilities Mobile Workforce Management step types if needed.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the step type. Must be unique for each DVM row.
CC&B Step Type value
WAM Step Type value
MWM Step Type value
FS_Order _SlotGroup
This indicates the Slot Group associated with an Appointment.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the slot group. Must be unique for each DVM row.
CC&B Slot Group value
MWM Slot Group value
This indicates the Location of a Meter. This DVM is applicable only to Oracle Utilities Customer Care and Billing and Oracle Utilities Mobile Workforce Management.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the meter location. Must be unique for each DVM row.
CC&B Meter Location Code value
MWM Meter Location Code value
This indicates the Priority Code of Orders. This DVM is used to map Priority Codes between Oracle Utilities Customer Care and Billing, Oracle Utilities Work and Asset Management v1.9.1.x and Oracle Utilities Mobile Workforce Management.
Note: In Oracle Utilities Mobile Workforce Management the Priority Code is mapped to the Queue.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the Priority Code. Must be unique for each DVM row.
CC&B Priority Code value
WAM Priority Code value
MWM PriorityCode value
FS_Order_TimeZone
This DVM is used to map Time Zones between Oracle Utilities Customer Care and Billing, Oracle Utilities Work and Asset Management v1.9.1.x and Oracle Utilities Mobile Workforce Management.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
CC&B Time Zone value
WAM Time Zone value
MWM Time Zone value
FS_Country_Code
This DVM is used to map Country Codes between Oracle Utilities Customer Care and Billing, Oracle Utilities Work and Asset Management v1.9.1.x and Oracle Utilities Mobile Workforce Management.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the Country Code. Must be unique for each DVM row.
CC&B Country Code value
WAM Country Code value
MWM Country Code value
FS_Language_Code
This DVM is used to map Language Codes between Oracle Utilities Customer Care and Billing, Oracle Utilities Work and Asset Management v1.9.1.x and Oracle Utilities Mobile Workforce Management. Currently the language code is only passed from Oracle Utilities Mobile Workforce Management to Oracle Utilities Customer Care and Billing for Installed Product.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the Language Code. Must be unique for each DVM row.
CC&B Language Code value
WAM Language Code value
MWM Language Code value
FS_Order_TypeCode_UseReadingOnBill
This DVM is used to map the Use on Bill Indicator on a Reading depending on the Order Type. The Use on Bill Indicator can be either true or false.
OU_CCB_ORDER_TYPE_CODE
USE_READING_ON_BILL
CC&B Order Type Code value
Use On Bill Indicator.
This indicates the Manufacturer of a Meter or Item. This DVM is applicable only to Oracle Utilities Customer Care and Billing and Oracle Utilities Mobile Workforce Management.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the meter/item manufacturer. Must be unique for each DVM row.
CC&B Meter/Item Manufacturer Code value
MWM uses the Meter/Item Manufacturer Code value stored as extendable lookup
FS_Order_ServiceWarningsCode
This indicates the Service Warnings associated with a Service Point. This DVM is applicable only to Oracle Utilities Customer Care and Billing and Oracle Utilities Mobile Workforce Management.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the service warnings code associated with a service point. Must be unique for each DVM row.
CC&B Service Warnings Code value
MWM uses the Service Warnings Code value stored as an extendable lookup
FS_Order_ServiceInstructionsCode
This indicates the Service Instructions associated with a Service Point. This DVM is applicable only to Oracle Utilities Customer Care and Billing and Oracle Utilities Mobile Workforce Management.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the service instructions code associated with a service point. Must be unique for each DVM row.
CC&B Service Instructions Code value
MWM uses the Service Instructions Code value stored as an extendable lookup
This indicates the Premise Type. This DVM is applicable only to Oracle Utilities Customer Care and Billing and Oracle Utilities Mobile Workforce Management.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the premise type code.
CC&B Premise Type Code value
MWM uses the Premise Type Code value stored as the M2-PremiseType extendable lookup
This indicates the Service Type. This DVM is applicable only to Oracle Utilities Customer Care and Billing and Oracle Utilities Mobile Workforce Management.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the Service Type code.
CC&B Service Type Code value
MWM Service Point
Type Code value
M2-ServicePointType
FS_BO
This indicates the business object mapping information. This DVM is applicable only between Oracle Utilities Customer Care and Billing, Oracle Utilities Mobile Workforce Management and Oracle Utilities Work and Asset Management/Oracle Utilities Operational Device Management v2.1.x.
MWM_BO
CCB_BO
WAM_BO
MWM business object names
CCB business object names
WAM/ODM business object names
FS_MO
This indicates the maintenance object mapping information. This DVM is applicable only between Oracle Utilities Customer Care and Billing, and Oracle Utilities Work and Asset Management/Oracle Utilities Operational Device Management v2.1.x.
CCB_MO
ODM_MO
CCB maintenance object names
WAM/ODM maintenance object names
Note: FS_MO and FS_BO are used to map attachment business objects and maintenance objects between Oracle Utilities Customer Care and Billing, Oracle Utilities Mobile Workforce Management and/or Oracle Utilities Work and Asset Management/Oracle Utilities Operational Device Management.
FS_ErrorCodes
This indicates the error codes mapping information. This DVM is applicable only between Oracle Utilities Customer Care and Billing and Oracle Utilities Work and Asset Management/Oracle Utilities Operational Device Management v2.1.x.
WAM_ErrorCode
CCB_ErrorCode
WAM message category and message number combination codes
CCB message category and message number combination codes
FS_SPNodeType
This indicates the service point mapping information. This DVM is applicable only between Oracle Utilities Customer Care and Billing and Oracle Utilities Work and Asset Management/Oracle Utilities Operational Device Management v2.1.x.
CCB_NodeType
ODM_SPType
CCB SP type information
WAM/ODM SP type information
FS_NodeDisposition
This indicates the service point disposition mapping information. This DVM is applicable only between Oracle Utilities Customer Care and Billing and Oracle Utilities Work and Asset Management/Oracle Utilities Operational Device Management v2.1.x.
CCB_NodeDisposition
ODM_NodeDisposition
CCB node disposition information
WAM/ODM SP node disposition information
FS_Order_ RegisterSeqCode
This indicates the register sequence mapping information across applications.
Common
OU_CCB_01
OU_WAM_01
OU_MWM_01
AIA common value: Describes the Register sequence
CC&B Register sequence values
WAM Register sequence values
MWM Register sequence values
FS_OkToEnterCode
This indicates the service point ok to enter or not ok mapping information. This DVM is applicable only between Oracle Utilities Customer Care and Billing and Oracle Utilities Work and Asset Management/Oracle Utilities Operational Device Management v2.1.x.
CCB_OkToEnterCode
ODM_OkToEnterCode
true
W2YS
false
W2NO
This indicates the service point life support mapping information. This DVM is applicable only between Oracle Utilities Customer Care and Billing and Oracle Utilities Work and Asset Management/Oracle Utilities Operational Device Management v2.1.x.
CCB_LifeSupportSensitiveLoad
ODM_LifeSupportSensitiveLoad
Y
W2LS
N
W2NO
Cross-References
Cross-references map and connect the records within the application network, and enable these applications to communicate in the same language. The integration server stores the relationship in a persistent way so that others can refer to it.
These are the cross-references for the integration layer:
Note: During implementation you do not need to do anything with this table. This table is populated by the integration processes as orders are created.
XREFTABLENAME
COLUMN NAME
DESCR
USAGE
FS_ORDER_ID
OU_CCB_01
CC&B FA ID
Populated by work order create business flow for orders that involve CC&B
COMMON
OU_MWM_01
MWM FO ID
Populated by work order create business flow for orders that involve MWM
OU_WAM_01
WAM SR ID
Populated by work order create business flow for orders that involve WAM
ROUTED_TO_CCB
Populated by work order create business flow for orders that are routed to CC&B
ROUTED_TO_WAM
Populated by work order create business flow for orders that are routed to WAM
ROUTED_TO_MWM
Populated by work order create business flow for orders that are routed to MWM
For more information about cross-references, refer to the Oracle Fusion Middleware Developer's Guide for Oracle SOA Core Extension under "Understanding Message Transformation, Enrichment, and Configuration" and “Creating Cross-References."
Updating MDS with AIA Meta Data
You must upload artifacts to MDS if any of the following occurs:
• New artifacts are created
• Extensions or customizations are made on artifacts
• DVM changes are made in AIAMetaData
• AIAConfigurationProperties.xml is changed
Oracle MDS repository contains all metadata. The contents under <AIA_HOME>/AIAMetaData are uploaded to SOA-MDS > apps/AIAMetaData. This includes specific schemas, WSDLS, DVMs, Cross Reference metada, default faultPolicies, AIAConfigurationProperties.xml and AIAEHNotification.xml
For more information about updating MDS, see Oracle Application Integration Architecture – Foundation Pack: Integration Developers Guide, “Updating MDS.”
You may need to bounce the SOA managed server to activate the changes uploaded to the MDS.
Update Configuration Properties
There are two steps to update the configuration:
• Download the configuration properties file from MDS using GetFieldWorkConfigFileDP.xml
Linux:
ant -f $SOA_HOME/aiafp/Install/AID/AIAInstallDriver.xml - DDeploymentPlan=$AIA_HOME/pips/FieldWork/DeploymentPlans/ GetFieldWorkConfigFileDP.xml -DPropertiesFile=$DOMAIN_LOCATION/soa/aia/bin/ AIAInstallProperties.xml
Windows:
ant -f %SOA_HOME%\aiafp\Install\AID\AIAInstallDriver.xml - DDeploymentPlan=%AIA_HOME%\pips\FieldWork\DeploymentPlans\GetFieldWo rkConfigFileDP.xml -DPropertiesFile=%DOMAIN_LOCATION%\soa\aia\bin\AIAInstallProperties.xml
It will prompt for user name and password. Pass the details.
• Edit the downloaded file in $AIA_HOME/config folder and make the changes that needs to updated and run the UpdateFieldWorkConfigFileDP.xml utility provided.
Linux:
ant -f $SOA_HOME/aiafp/Install/AID/AIAInstallDriver.xml - DDeploymentPlan=$AIA_HOME/pips/FieldWork/DeploymentPlans/ UpdateFieldWorkConfigFileDP.xml -DPropertiesFile=$DOMAIN_LOCATION/soa/aia/bin/ AIAInstallProperties.xml
Windows:
ant -f %SOA_HOME%\aiafp\Install\AID\AIAInstallDriver.xml - DDeploymentPlan=%AIA_HOME%\pips\FieldWork\DeploymentPlans\UpdateField WorkConfigFileDP.xml -DPropertiesFile=%DOMAIN_LOCATION%\soa\aia\bin\AIAInstallProperties.xml
Deploying Individual Composites/Undeploying Composites and Updating MDS
FieldWorkCustomDP.xml utility is provided for this purpose. Edit the file. Add as per the comments in the file and run the command accordingly.
Linux:
ant -f $SOA_HOME/aiafp/Install/AID/AIAInstallDriver.xml - DDeploymentPlan=$AIA_HOME/pips/FieldWork/DeploymentPlans/ FieldWorkCustomDP.xml -DPropertiesFile=$DOMAIN_LOCATION/soa/aia/bin/ AIAInstallProperties.xml
Windows:
ant -f %SOA_HOME%\aiafp\Install\AID\AIAInstallDriver.xml - DDeploymentPlan=%AIA_HOME%\pips\FieldWork\DeploymentPlans\FieldWorkC ustomDP.xml -DPropertiesFile=%DOMAIN_LOCATION%\soa\aia\bin\AIAInstallProperties.xml
It will prompt for user name and password. Provide these details.
Update MDS with AIAMetaData
Update the appropriate WSDL/DVM files in AIAMetData under $AIA_HOME. SOA Core Extensions for 12.2.1 provides UpdateMetaDataDP.xml utility for updating MDS.
• Source the file aiaenv.sh (located at Middleware Home/user_projects/domains/soa_domain/soa/aia/bin) by executing the following command:
source aiaenv.sh
• Browse to the folder at $DOMAIN_LOCATION/soa/aia/MDSUtils/UpdateMetaDataDP.xml and open the deployment plan file, UpdateMetaDataDP.xml.
• Update the file UpdateMetaDataDP.xml by inserting include tags for each resource group that you want to add to the MDS:
Example to update DVM:
<fileset dir="${env.SERVICES_LOCATION}/AIAMetaData">
<include name="dvm/FS_Order_ServiceTypeCode.dvm" />
</fileset>
Example to update wsdl file:
<include name="AIAComponents/ApplicationConnectorServiceLibrary/OUWAM/V2/RequestorABCS/ProcessWorkOrderCancelOUWAMUtilitiesReqABCSImplV2.wsdl" />
• Run the update utility.
Linux:
ant -f $SOA_HOME/aiafp/Install/AID/AIAInstallDriver.xml - DDeploymentPlan=$DOMAIN_LOCATION/soa/aia/MDSUtils/ UpdateMetaDataDP.xml -DPropertiesFile=$DOMAIN_LOCATION/soa/aia/bin/ AIAInstallProperties.xml
Windows:
%DOMAIN_LOCATION%\soa\aia\MDSUtils\UpdateMetaDataDP.xml -DPropertiesFile=%DOMAIN_LOCATION%\soa\aia\bin\AIAInstallProperties.xml
Error Notification Setup
Based on the roles defined for the services, email notifications are sent if a service errors out.
For more information about error handling and error notifications, refer to the Configuring Oracle AIA Processes for Error Handling and Trace Logging section in the Oracle Fusion Middleware Developer's Guide for Oracle SOA Core Extension.
SOA Infrastructure Common Properties
Payload Validation property defined in SOA Infrastructure should be turned off.
This property is defined on SOA level under Common Properties and can be overridden for each process.
Make sure your implementation always has Payload Validation disabled.
