Integration Pack Software Requirements
The following software and applications must be installed and configured before installing the integration pack. For more details, refer to product-specific installation guides.
Participating Applications
• Oracle Utilities Customer Care and Billing V2.3.1.x, V2.4.0.3, V2.5.0.x, or higher
• Oracle Utilities Mobile Workforce Management V2.2.x, V2.3.x, or higher
• Oracle Utilities Work and Asset Management V2.1.x, V1.9.1.2.4, or higher
Oracle SOA/WebLogic Server
• WebLogic Server V12.2.1.1.0
• Oracle SOA Suite 12.2.1.1.0
Note: SOA Core extensions are not part of SOA Suite 12.2.1.1 by default. You must upgrade the domain.
For the most up-to-date supported edge application versions, refer to the Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1) on My Oracle Support.
