Integration Pack Software Requirements
The following software and applications must be installed and configured before installing the integration pack:
Participating Applications
• Oracle Utilities Customer Care and Billing V2.3.1.x, V2.4.0.3, or V2.5.0.x
• Oracle Utilities Mobile Workforce Management V2.2.x or V2.3.x
• Oracle Utilities Work and Asset Management V2.1.x or V1.9.1.2.4
Oracle SOA/WebLogic Server
• WebLogic Server V12.2.1.0.0 and Oracle SOA Suite 12.2.1
Note: SOA Core extensions are not part of SOA Suite 12.2.1 by default. You must upgrade the domain.
For the most up-to-date supported edge application versions, refer to the Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1) on My Oracle Support.
