Business Processes
The integration scope supports the following business processes:
Storeroom Sync from ERP SCM to WACS
The storeroom integration transfers the sub inventory in Oracle Fusion ERP Cloud as storeroom in Oracle Utilities Work and Asset Cloud Service:
• Active Storeroom Synchronization from to Oracle Utilities Work and Asset Cloud Service
• Inactive Storeroom Synchronization from Oracle Fusion ERP Cloud to Oracle Utilities Work and Asset Cloud Service
This process synchronizes the “Active” sub inventories from to storerooms in Oracle Utilities Work and Asset Cloud Service in bulk and incremental fashion.
This process synchronizes the sub inventories in “Inactive” status from to storerooms in Oracle Utilities Work and Asset Cloud Service in bulk and incrementally.Shows the Inactive Storeroom Synchronization process.
Stock Item Details Sync from ERP SCM to WACS
Stock Item Details Integration synchronizes the following data from Fusion Inventory to Oracle Utilities Work and Asset Cloud Service:
• Stock Item Detail Bulk Load from Oracle Fusion ERP Cloud to Oracle Utilities Work and Asset Cloud Service
• Stock Item Detail Incremental Sync from Oracle Fusion ERP Cloud to Oracle Utilities Work and Asset Cloud Service
• Item Quantities and Average Unit Price Sync from Oracle Fusion ERP Cloud to Oracle Utilities Work and Asset Cloud Service
Item assignments in Oracle Fusion ERP Cloud sub inventory will be synchronized as Stock Item Details in Oracle Utilities Work and Asset Cloud Service storerooms. The bulk load will synchronize full item extract from Oracle Fusion ERP Cloud to SID in Oracle Utilities Work and Asset Cloud Service.
Incremental synchronization will use create/update item events to synchronize the item to SIDs in Oracle Utilities Work and Asset Cloud Service incrementally.
On-hand quantity and average unit price for an item in Oracle Fusion ERP Cloud sub inventory will be synchronized to Item Quantity in Oracle Utilities Work and Asset Cloud Service storeroom.Shows the Stock Item Details Sync process details.
Material Reservation Integration from WACS to ERP SCM
The Material Reservation integration synchronizes the Material Activity Resource Requirement reservations in Oracle Utilities Work and Asset Cloud Service as User Defined Reservations in Oracle Supply Chain Management.Shows the Material Reservation integration details.
Material Request Integration from WACS to ERP SCM
The Material Request integration expense type creates a supply request in Oracle Fusion ERP Cloud after a Material Request is created in Oracle Utilities Work and Asset Cloud Service. This supply request creates an expense type transfer order. The pick wave for the transfer order is also created in Oracle Supply Chain Management nearer to the required by date.
The integration includes the following flows:
Supply Request Creation
The material request from Oracle Utilities Work and Asset Cloud Service creates an expense type supply request in Oracle Supply Chain Management. This supply request gets converted to expense type transfer order in Oracle Supply Chain Management through supply chain orchestration process of Oracle Fusion.
Pick Wave Creation
Closer to the transfer order required by date, the integration creates a pick wave for each transfer order. It also reduces the user defined reservation by appropriate quantity if the Oracle Utilities Work and Asset Cloud Service material request line has a material ARR attached to it with reservation.Shows the Material Request Creation integration details.
Material Issue Integration from ERP SCM to WACS
The Material Issue integration intended to synchronize the issue information for the material requested from inventory by a Oracle Utilities Work and Asset Cloud Service activity when inventory is owned by Oracle Supply Chain Management when the pickup and shipment is confirmed.
Through material request integration flows, the Oracle Utilities Work and Asset Cloud Service material request generates expense transfer order in Oracle Supply Chain Management and pick wave for that transfer order closer to required by date. The transfer order will be executed and closed once the material is picked up for all the lines and lines are closed. As the material for transfer order lines gets picked up, this information should be fed back to Oracle Utilities Work and Asset Cloud Service as a material issue for the material request line. This will allow Oracle Utilities Work and Asset Cloud Service to close the material request line and proceed further in activity execution.
Material Demand Forecast Integration from WACS to ERP SCM
This integration will read the Oracle Utilities Work and Asset Cloud Service batch file for Material Demand upload as external forecast to Oracle Supply Chain Management to allow replenishment planning for Oracle Supply Chain Management subinventories.
For multiple files, the integration process run files to avoid duplicate records.
• Material Demand FTP Forecast
• Material Demand OS Forecast
This integration reads the Material Demand batch file from FTP server and uploads it as external forecast to Oracle Supply Chain Management Planning through external forecast FBDI.
This integration reads the Material Demand batch file from Object Storage and uploads it as external forecast to Oracle Supply Chain Management through external forecast FBDI.
