External Fieldwork System Integration
The following section describes functionality provided for integrating your field activities with an external system.
Separate module. Field activity integration functionality is associated with separate Field Activity Integration module. If this module is not applicable to your business you may turn it off. Refer to Turn Off A Function Module for more information.
