Setting Up TOU Groups
TOU Groups may be used to group together time of use codes, which are included in a meter configuration. It is also used in TOU mapping and pricing functionality.
Fastpath:
Refer to Grouping of TOU Codes for more information about the TOU group's role in TOU mapping and pricing.
Open to define your TOU Groups.
Description of Page
Enter a unique TOU Group and Description for the TOU group.
Enter the Collection Time of Use codes. This is a list of time of use codes that define the time of use periods to be used for certain TOU maps. For each time of use code, you may indicate a TOU Sequence to indicate the relative order or relative priority of each TOU for the TOU group. Refer to Grouping of TOU Codes for more information.
