SA Types And The Financial Design
In this section, we provide an example of how our SA Types map to Bill Segment Types, Payment Segment Types, and Adjustment Profiles. This example is meant to help solidify the power of the financial model, it is not necessarily indicative of how your specific implementation will look.
Warning:
If you are not comfortable with the topics described in Defining Financial Transaction Options, the following table will not make sense.
Division/SA Type
Distribution Code
Bill Segment Type
Adjustment Profiles
CA/G-RES
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES, BUDGET
CA/G-COM
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/G-IND
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/W-RES
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/W-COM
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/W-IND
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/E-RES
A/R-UTIL
SP-RATED
NORMAL
CA/E-COM
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/E-IND
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/WW-RES
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/WW-COM
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/WW-IND
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/CABLE
A/R-UTIL
SP-RATED
NORMAL
BALXFER, MISCFEES
CA/E-COY
E-COMP
COMPUSAG
CA/G-COY
E-COMP
COMPUSAG
CA/W-COY
E-COMP
COMPUSAG
CA/WO-STD
NORMAL
BALXFER
CA/WO-LIA
NORMAL
BALXFER
CA/CONNECT
NORMAL
BALXFER, MISCFEES
CA/CHARITY
A/P-CHAR
RECUR
CHARITY
CHARITY
CA/PA-REGU
A/R-ARRG
RECUR-AS
NORMAL
BALXFER, MISCFEES, DPA
CA/PA-UNRE
A/R-ARRG
RECUR-AS
NORMAL
CA/MERCH-I
A/R-MRCH
RECUR-AS
NORMAL
BALXFER, MISCFEES, MERCH
CA/DEP-I
A/P-DEPO
RECUR-AS
NORMAL
BALXFER, MISCFEES, DEPOSIT
CA/ONETIME
A/R-UTIL
BILLCHRG
NORMAL
BALXFER, MISCFEES
CA/OVR UNDR
EXP-OV/UND
NORMAL
CA/OVERPAY
A/P-OVER
NORMAL
BALXFER
CA/SUSPENSE
A/R-SUSP
NORMAL
CA/NBB
A/P-OVPY
NORMAL
BALXFER, MISCFEES, NBB
If you operate in a deregulated environment, you will also have additional SA types as described under Designing Your SA Types And Start Options For Sub SAs and Designing SA Types For Service Provider Financial Settlements you may have additional SA types.
