Setting Up SA Relationships For SA Types
This portal is used to maintain SA Type SA Relationship Types.
You can access the portal from Admin > Open Market > SA Type SA Relationship Type. You are brought to a query portal with options for searching for a specific SA Type SA Relationship Type. Once a record is selected, you are brought to the maintenance portal to view and maintain the selected record.
The SA Type SA Relationship Type zone shows the details of the SA Type SA Relationship Type. Refer to the zone’s embedded help for more information.
