Use Workflow & Notification to Interface Info
Workflow and notification allows you to send information to a third party via an extract program or via XAI. The service credit event has its own logic for interfacing via an extract program, so you would use workflow and notification only if you need to interface to the third party via XAI.
Fastpath:
Refer to Designing Notification Downloads for more information.
