Creating a Notification Upload Staging Record
To create an NUS record directly, you need the following information:
- External System (to point to a service provider)
- NUS Type
You also need to populate relevant data using either context or characteristics. For example, if a change to a person's name should trigger a letter to the customer and an outbound message, the Person ID must be referenced.
The process that creates the NUS must determine the appropriate external system based on the business rules. If the steps that need to be taken as a result of this system condition are based on an internal practice, the external system could be something like "SYSTEM". That external system would reference an appropriate workflow process profile that defines the appropriate workflow process based on the NUS type.
Determining the NUS type is similar to determining the NDS type as described in the previous section.
Refer to Designing Notification Upload Types and Setting Up Notification Upload Types for more information.
