Field Order Print in BI Publisher- CI_FOPRNT
Field Order Print in batch for BI Publisher is not supported yet.
Parameters
Parameter |
Parameter Code |
Description |
CC&B user |
P_USER_ID |
No default value. Required. Returns an error message if user ID is null, empty or does not exist in database. |
Batch Switch |
P_BATCH_SW |
For a single FO print, Batch Switch is 'No' and for multiple FO print, Batch Switch is 'Yes'. |
First FO |
P_FROM_FO_ID |
First FO ID to print for the FO Range. |
Last FO |
P_TO_FO_ID |
Last FO ID to print for the FO Range. |
Batch Code |
P_BATCH_CD |
Batch Code passed in by the system the report is submitted in batch. Only field orders that reference this batch code are selected. |
Batch Number |
P_BATCH_NBR |
Batch Code passed in by the system the report is submitted in batch. Only field orders that reference this batch number are selected. |
Extract Algorithm |
P_EXTRACT_ALG |
Passed in by the system the report is submitted in batch. Only field orders whose dispatch groups reference this FO extract algorithm are selected. |
Report Description
This report is used with BI Publisher to display the Field Order information for the field order ID entered in the input parameters. Refer to the description of the parameters above. The field order will only be displayed if the field order's status is dispatched.
The following sections highlight the data that is extracted for this report.
