Overriding Zone Parameters
Implementations may override the value of a base owned zone parameter only if the zone type definition allows such override. The override parameter value is enabled for a specific base owned parameter when the related zone type parameter usage is set to Zone - Override Allowed.
You may use the override parameter capability to provide alternative or additional custom query options for a base owned multi-query zone.
