Business Object - Summary
This page summarizes business object information in a high level. Open this page using Admin > System > Business Object > Search and then navigate to the Summary tab.
Description of Page
The contents of this section describe the zones that are available on this portal.
The General Information zone displays main attributes of the business object.
Click the View Schema hyperlink to view the business object's expanded schema definition. Doing this opens the schema viewer window.
Click the View XSD hyperlink to view the business object's expanded schema definition in XSD format.
The Business Object Hierarchy zone displays in a tree view format the hierarchy of child business object associated with the current business object. It also shows the current business object's immediate parent business object.
For business objects with a lifecycle, the Lifecycle Display zone shows a graphical depiction of the lifecycle. Refer to the embedded help of that zone for more information.
The Options zone summarizes business object and state specific options throughout the inheritance chain.
The Rules zone summarizes business object and state specific rules throughout the inheritance chain.
