Defining Process Flow Types
This portal is used to maintain process flow types.
Refer to Understanding Process Flows for more information.
You can access the portal from the
The following zones may appear as part of the portal's Main tab page
- Process Flow Type List. This zone lists all process flow types. Broadcast a record to display the details of the selected process flow type.
- Process Flow Type. This zone provides information about the selected process flow type.
