Setting Up Notification Event Types
This portal is used to display and maintain a Notification Event Type.
Notification Event Types are system events used to send communications or notifications to customers.
You can access the portal from Admin > Customer > Notification Event Type.
This is a standard All-In-One Portal.
Refer to the embedded help text for more information.
